Another Pole Building Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 05:48 AM   #1
Another pole building insulation question
I'm planning on having a pole building installed for a home. The building will be framed in wood and covered with R panel. The 5" square poles will be set 10" apart with 2" x 6"'s as girts and the metal screwed directly to them. I plan on installing 2" x 4"'s as inside girts and then drywall. I'm having additional trusses set at 24" OC also. My question is about insulation, I plan on having open cell spray on insulation installed 3"-3.5" thick on the walls and roof. Will this be enough for the walls and will adding 12" of blown in insulation in the ceiling create a problem with moisture. I will have gable vents installed with a fan for our hot summers here in Louisiana. I'm trying to go as energy efficient as possible but don't want to create future problems.
Radrob777 is offline   Reply With Quote
new wall insulation question s002wjh Building & Construction 9 01-05-2012 01:57 PM
yet one more insulation question Mike in Arkansas General DIY Discussions 6 11-11-2010 09:47 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Insulation question Branden Building & Construction 1 08-03-2010 01:02 PM
