Old 06-06-2011, 05:55 PM   #1
Another ledger board question
I noticed some rot on my siding just above the deck board on my back yard deck. My house is "L" shaped and the deck was built along both walls of the interior angle of the "L" shape. I pulled a few decking boards and besides finding a few shockingly large spiders I found that the builder of the deck was an idiot. The 2 ledger boards were nailed directly onto the siding of the house and of course no flashing was used.
My feeling is that I am going to have to tear down the deck, replace both ledgers properly, add flashing, and rebuild the subdeck and redeck the top. Oh, and repair the siding in the process. Can anyone with a lot of experience in decking please confirm this for me or tell me that there is an easier way??
Needhelp1 is offline   Reply With Quote
Old 06-06-2011, 05:57 PM   #2
I would tear down. And properly remove the siding and flash it correctly. Use the PVC flashing as it won't corrode with the pt framing. Use grace ice and water behind the deck ledger board as well
dvatt is offline   Reply With Quote
Old 06-06-2011, 06:00 PM   #3
That's what I thought.
what is "grace ice and water"?
Old 06-06-2011, 06:54 PM   #4
It is a flexible rubbery flashing used on roofs. Place it behind the ledger to prevent water from getting in where the ledger locks go. Fastenmaster makes these and they are in place of lag screws
Old 06-06-2011, 07:04 PM   #5
Moderator
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Clothes taking longer to dry?
Tags
deck, ledger, ledger board, ledger repair, repair
Building Deck, Ledger question bowanna03 Building & Construction 14 06-14-2011 10:05 AM
Installing backer board question zrooster99 Flooring 11 01-23-2011 05:32 PM
question about cement board Tenchi Building & Construction 2 11-21-2010 10:13 PM
Best way to attach a rafter to a ledger board? cocean Building & Construction 11 06-27-2010 05:55 PM
Question about board & batten houses Lilamilz Carpentry 2 07-21-2009 08:50 AM
