Another Deck Question - Second Level - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 12:58 PM   #1
Rewards Points: 105
Another deck question - second level
I'm still working on my 18' x 30' second story deck and I have a question. I have poured the four footers w/ the J-bolt. I have also installed the ledger on the house band and properly flashed it. What is the best way to establish a level line across posts that is even with the bottom of the ledger? I would like to notch the posts to install the (3) 2x12 beam. I was thinking of using a self-leveling, rotating laser on a tripod.
Any suggestions?
Bugman1400 is offline   Reply With Quote
Old 05-15-2013, 03:59 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
water level works ..... I know it's not high tech, but cheap and easy
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
MTN REMODEL LLC (05-15-2013), oh'mike (05-15-2013)
Old 05-15-2013, 04:22 PM   #3
GBrackins's Avatar
sorry, I have to ask ......
how high above the ground is the deck and what size and spacing are the columns?
Gary
Old 05-15-2013, 05:39 PM   #4
Rewards Points: 105
The deck is 9 ft off the ground and the 8x8 columns are spaced 9 ft 11 in.
Old 05-15-2013, 05:50 PM   #5
GBrackins's Avatar
good!
just wanted to make sure it was 17' off the ground with 15' spans and 4x4's ......
Good luck!
Gary
Old 05-15-2013, 06:10 PM   #6
Lord of Slums
Rewards Points: 1,974
Those water levels are awesome. I use washer fluid because it is easier to see.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-15-2013, 06:43 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Washer fluid... great idea!!! My hands, and sometimes my shirt/pants and hands often come back with food dye all over them when I space out and forget to cap it.
I feel so much more confident with the water level verse the laser levels, or even a good transit and the accompaning mesurement transfer.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-15-2013, 06:45 PM   #8
DIY staff
Rewards Points: 7,174
Tried and true----I still use one for siding and foundations----I can't afford a good enough laser for use out in the sun----
Old 05-15-2013, 06:59 PM   #9
Rewards Points: 105
Can you elaborate a bit more on using a typical level? I assume you are referring to just putting a joist in a hanger on the ledger and placing the level on top of the joist and guiding it up or down the vertical post until the "bubble is in the middle" and mark.
Old 05-15-2013, 07:15 PM   #10
GBrackins's Avatar
check out the video it should help ..... http://www.bing.com/videos/search?q=...=0&FORM=NVPFVR
not a typical carpenters bubble level, a water level.
Gary
Old 05-15-2013, 07:30 PM   #11
Rewards Points: 105
I have not seen that before. It looks like redneck engineering but, I guess it works!
Thanks!
Old 05-15-2013, 07:33 PM   #12
DIY staff
A water level is just a roll of clear plastic tubing filled with water ( or window juice)
I get the size that fits my wet saw so I can reuse the tubing----
Old 05-15-2013, 07:44 PM   #13
Thanks!
If ya think about it, many of our most usefull tools are the simplest/redneck.
Keep the bubbles out though.
Old 05-15-2013, 07:49 PM   #14
I like the 3/4", fill it with Jack Daniels, and empty it at quitting time...... Hey.... guess it is a little redneckish
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 05-15-2013, 08:27 PM   #15
GBrackins's Avatar
or shine if your a hillbilly
Gary
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Question on enlarging existing deck gbear14 Building & Construction 1 07-18-2011 01:55 PM
new second story deck stair, platform question walt1122 Building & Construction 10 11-12-2010 10:52 AM
Deck Question gmhammes Building & Construction 19 05-28-2010 11:34 AM
Deck Ledger Question Greg D Building & Construction 9 04-08-2010 08:57 AM
