-   -   Another deck question - second level (http://www.diychatroom.com/f19/another-deck-question-second-level-179638/)
Bugman1400 05-15-2013 12:58 PM
I'm still working on my 18' x 30' second story deck and I have a question. I have poured the four footers w/ the J-bolt. I have also installed the ledger on the house band and properly flashed it. What is the best way to establish a level line across posts that is even with the bottom of the ledger? I would like to notch the posts to install the (3) 2x12 beam. I was thinking of using a self-leveling, rotating laser on a tripod.
Any suggestions?
GBrackins 05-15-2013 03:59 PM
water level works ..... I know it's not high tech, but cheap and easy
GBrackins 05-15-2013 04:22 PM
sorry, I have to ask ......
how high above the ground is the deck and what size and spacing are the columns?
Bugman1400 05-15-2013 05:39 PM
The deck is 9 ft off the ground and the 8x8 columns are spaced 9 ft 11 in.
GBrackins 05-15-2013 05:50 PM
good!
just wanted to make sure it was 17' off the ground with 15' spans and 4x4's ......
Good luck!
mj12 05-15-2013 06:10 PM
Those water levels are awesome. I use washer fluid because it is easier to see.
MTN REMODEL LLC 05-15-2013 06:43 PM
Washer fluid... great idea!!! My hands, and sometimes my shirt/pants and hands often come back with food dye all over them when I space out and forget to cap it.
I feel so much more confident with the water level verse the laser levels, or even a good transit and the accompaning mesurement transfer.
:thumbsup:
oh'mike 05-15-2013 06:45 PM
Tried and true----I still use one for siding and foundations----I can't afford a good enough laser for use out in the sun----
Bugman1400 05-15-2013 06:59 PM
Can you elaborate a bit more on using a typical level? I assume you are referring to just putting a joist in a hanger on the ledger and placing the level on top of the joist and guiding it up or down the vertical post until the "bubble is in the middle" and mark.
GBrackins 05-15-2013 07:15 PM
check out the video it should help ..... http://www.bing.com/videos/search?q=...=0&FORM=NVPFVR
not a typical carpenters bubble level, a water level.
Bugman1400 05-15-2013 07:30 PM
I have not seen that before. It looks like redneck engineering but, I guess it works!
Thanks!
oh'mike 05-15-2013 07:33 PM
A water level is just a roll of clear plastic tubing filled with water ( or window juice)
I get the size that fits my wet saw so I can reuse the tubing----
MTN REMODEL LLC 05-15-2013 07:44 PM
Thanks!
If ya think about it, many of our most usefull tools are the simplest/redneck.
Keep the bubbles out though.
MTN REMODEL LLC 05-15-2013 07:49 PM
I like the 3/4", fill it with Jack Daniels, and empty it at quitting time...... Hey.... guess it is a little redneckish:huh:
GBrackins 05-15-2013 08:27 PM
or shine if your a hillbilly
