Another Deck Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 09:01 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Another deck question
To make a really long and annoying story short, my hud inspector who previously approved the property (multiple times) is now telling me that the deck needs a step. This along with various other annoying issues that had previously passed add up to quite an overwhelming list.
My question : what is the code requirement for a step off of a deck?
In California by the way.
Journeyman Plumber
Old 03-12-2014, 09:27 PM   #2
Msradell's Avatar
Rewards Points: 262
It depends on how tall the deck is!
Msradell is offline   Reply With Quote
Old 03-13-2014, 09:08 AM   #3
Rewards Points: 3,130
Why not ask the inspector? I don't know what code says, but one of my decks is 16 inches off the ground and has no step. Should it? Don't know, but it passed inspection.
Old 03-13-2014, 11:45 AM   #4
Civil Engineer
Rewards Points: 4,854
This is a building code issue, which can best be answered by the local building code enforcement official.
Old 03-13-2014, 02:03 PM   #5
Rewards Points: 268
If the deck is under 8" off ground for any 3' section it should not need a step. If it is over 18" off ground it needs railing. If more than 1 step is required it needs a graspable hand rail. At least that in the code in my area.
JustinK is online now   Reply With Quote
Old 03-13-2014, 03:14 PM   #6
A good illustration of how codes differ in different areas. Here, a railing is not required unless the deck is more than 30 inches off the ground. Also, one of mine has four steps, another has three. No handrails required.
Old 03-13-2014, 04:35 PM   #7
Rewards Points: 268
Some townships around me do not require building permit (just zoning) for decks under 30 inches so I guess you can do what ever you want because no one is coming to inspect it.
Old 03-13-2014, 06:07 PM   #8
To make a long story short, if your dealing with HUD just add the step.
ron45 is offline   Reply With Quote
Old 03-13-2014, 08:06 PM   #9
Rewards Points: 2,638
I have never seen a graspable hand rail on a deck, in my life. I think it is code here, just not enforced.
SPS-1 is offline   Reply With Quote
Deck Framing Question ModernDayDarwin Building & Construction 7 05-18-2013 08:28 PM
Deck Railing Question RodBarney Building & Construction 17 04-20-2013 10:52 PM
Attached deck question. Bugman1400 Building & Construction 31 09-09-2012 11:11 AM
16 x 20 deck question canyonbc Carpentry 9 01-12-2010 08:01 PM
Building a deck - another project for later this summer (Question re: materials) DyerWolf Carpentry 8 05-07-2009 01:41 PM
