Another 2x6 Cathedral Ceiling - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 12:17 AM   #16
Registered User
Rewards Points: 4,924
Good idea, Andy. Scroll to the last two tables here: http://publicecodes.citation.com/ico...002_par023.htm
You can check your snow load for the 2x6 rafters 24"o.c. to see if they will work or not, remember to add the drywall now on the rake to your dead/live loads. Won't work for the 4x's you want though, check around as said.
Gary
Old 11-22-2011, 10:07 AM   #17
I am located in MA. I will look into this thanks!
juststarted is offline   Reply With Quote
Old 11-22-2011, 05:27 PM   #18
Great info Gary thanks. I did some load calculations based on the information I found and a 50# load (on the belt of 30-35 snow so just went high with 35 and 15dead).
I did some rethinking about what would make the most sense and rather than 4X's I think two 2X's on either side of a rafter is better. Connecting them in between. I could then cover them and make them look like one "beam".
This would be a more traditional method and easier in some ways.
Doing the math I would need 3 of these "beams" to properly support the load but may be able to cut that down by using something stronger than pine and just 1/2" through bolts. The weakness is in the connections, not in the tension of the boards. Also these calculations are based on no collar ties (or rafter ties depending on what you want to call them all that height) so I should have a pretty good factor of safety in these calculations.
Thanks for all the help so far! I will keep things posted as they move along.
Condensation/Leak on Cathedral ceiling with no attic. benbern125 Remodeling 3 03-02-2011 04:04 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 08:54 PM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 08:06 PM
ventilation baffles in cathedral ceiling HHac8014 Building & Construction 10 05-03-2010 11:32 AM
Cathedral ceiling sharp Building & Construction 5 02-26-2010 11:18 PM
