Angle Iron Instead Of Brick Ledge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2010, 11:00 AM   #1
Angle Iron instead of brick ledge
I have a brick home with a carport atttached. I would like to close in the carport for additional living area. Can you use angle iron for a brick ledge?
Also what is the best way to attache the angle iron to the concrete slab and sealing it?
marlo is offline   Reply With Quote
Old 06-06-2010, 07:07 PM   #2
Rewards Points: 4,726
not sure why you'd need a brick ledge unless attaching to the side of the floor,,, if so, we'd use 3/8" lags & lead drop-ins thru drilled holes,,, however, we'd also prefer conc instead to accompany the steel,,, don't forget flashing & escape route for the water,,, your mason should be knowledgeable for this work, too !
good luck !
Old 06-06-2010, 08:04 PM   #3
Concrete & Masonry
Rewards Points: 616
How much brick are you talking? Just a beltline or the entire wall, includigng over the OH door?
jomama45 is offline   Reply With Quote
Old 06-06-2010, 08:27 PM   #4
The entire wall. It's 20 feet long.
Old 06-06-2010, 08:31 PM   #5
Concrete & Masonry
Rewards Points: 616
Does it have a height??????
Old 06-06-2010, 08:40 PM   #6
The wall height is 7'8"
Old 06-06-2010, 08:47 PM   #7
Concrete & Masonry
Rewards Points: 616
I'd be aprehensive to lay that much full veneer on an anchored angle iron personally. IF an engineer specced the angle & anchorments, based on strength & pull-out, I'd have no problem doing it though.
Another option I would offer a HO would be to saw the brick into thin brick & adhere over diamond mesh & tarpaper to keep the weight down.
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 01:03 PM
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 09:46 AM
Drilling angle iron to wood... atiffarooqi Building & Construction 2 06-24-2009 08:46 PM
Flashing material on top of brick ledge... MLO Building & Construction 16 10-31-2007 10:17 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
