Anderson Vs. Pella Exterior French Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 02:12 PM   #1
Anderson vs. Pella Exterior French Doors
We are in the market for 3 sets of exterior french doors to replace our existing builders-grade ones that are warped and not closing properly. Both Anderson and Pella reps came to our house. Pella is $2K more than Anderson. I'm trying to understand if it's worth it. Both doors look to be the same on the outside. I realize that they are obviously constructed differently. But is it worth $2K per door?
Beth R is offline   Reply With Quote
Old 06-11-2010, 02:24 PM   #2
Rewards Points: 5,336
Pella doors are wrapped on the exterior with aluminum. The Andersens have a urethane finish on them. I've been putting in the Andersens forever and have never had an issue with them. I have removed doors installed by others that had rotted due to idiotic installation practices, but that will happen to any door or window.
Ron
Old 06-11-2010, 03:59 PM   #3
The exterior trim on my Pella sliding glass doors seperated from the glass the year after they were installed
Pella would have to be a LOT less for me to buy another Pella door
Old 06-11-2010, 08:05 PM   #4
DIY staff
Rewards Points: 7,174
I've been installing Anderson doors for many years---Never a call back.
Pella on the other hand--I charge a BIG extra to install because of call backs and complaints.
Go with Anderson--You will be glad you did.----Mike----
Old 06-12-2010, 12:09 AM   #5
Rewards Points: 410
Integrity ( Marvin) is worth looking at also.
High Gear is offline   Reply With Quote
Old 11-10-2010, 06:45 AM   #6
What Mike said. I have dealt with both over my 26 yrs as a contractor, never or rarely a problem with Andersen, and they stand behind their products. Pella does not!!
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (11-10-2010)
Anderson and Pella installers beerdog General DIY Discussions 22 09-20-2011 02:28 PM
Exterior Anderson French Doors baclarks Carpentry 4 01-25-2010 07:43 AM
Replacement Windows - Pella, Anderson, Marvin? The what to do about blinds? ms_obvious General DIY Discussions 3 11-29-2009 09:16 AM
Anderson Slider Doors Maralind Building & Construction 4 01-25-2009 09:15 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
