Old 07-27-2011, 08:20 AM   #1
Share |
Anderson Casement Windows Problems
Hi! Our home has Anderson casement windows throughout...they were installed in the late 1980's. They all look nice but each of them have problems opening fully to 90 degrees...or anywhere even close to that. Some will open to a max of 30-45 degrees...most cannot get open that much. If we try to open them more, either the handle freezes when we try to close them or the handle just cannot grip...and we have to close the window from the outside by hand. Keeping the window open to the minimal degree enables us full control. BUT, it really does not allow much air flow!
Being new to casement windows I have no idea what we can do to allow full opening/closing capabilities via the crank. I did try to lubricate w silicone but it seemingly did not help. I suspect the cranking mechanisms on those windows that seem to lose their grip once opened to a certain degree...is broken. But what about those windows that the crank just simply will not move, once the windows have been opened to a certain point? Why can we open the windows using the crank but cannot close them?
Thanks in advance for any/all info on this!
I E S is offline   Reply With Quote
Old 07-27-2011, 09:38 AM   #2
Experienced
Jackofall1's Avatar
Welcom I E S, to the best darn DIY'r site on the web.
Have you contacted your local Anderson rep to see about replacement parts?, that is where I would start, mechanisms that old are bond to be worn.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Tom Struble (07-27-2011)
Old 08-02-2011, 12:37 PM   #3
Our new home has 54 Anderson casement windows that were installed in 1991. Many were hard to open, some that chattered when opening or closing and a few that just wouldn't open past a few degrees. We opened each window all the way, flushed out the window mechanism area with water to removed 20 years of dirt and bugs and cleaned any old dirt buildup off the track with a clean rag. Then sprayed liberal quantities of silicone spray purchased at NAPA Auto Parts on the lower and upper stainless steel tracks. Our windows now open with ease. Try this simple solution before going to the effort and expense of replacing any mechanisms.
prowe is offline   Reply With Quote
The Following User Says Thank You to prowe For This Useful Post:
oh'mike (08-02-2011)
Old 08-02-2011, 04:32 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Correct.
That's what has to be done. I take the stop screws out top and bottom an remove the window. pay strict attention on the stainless steel tracks on the bottom and top of the sash,
Old 08-02-2011, 05:35 PM   #5
DIY staff
The crank handles are easy to get and replace if they are stripped.
The handles are a soft metal and will strip if the set screw was not tightened properly.
Prowe nailed this one--most times a simple clean and lube job will have them working like new.
oh'mike is online now   Reply With Quote
Can you flash replacement windows with existing siding? twobyfour2 Windows and Doors 3 05-31-2011 09:29 PM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 06:43 PM
Anderson Casement Windows is it Worth Repairing? MCASEY328 Building & Construction 2 07-28-2010 08:25 PM
Help with old Anderson windows JohnR Building & Construction 1 06-14-2009 06:19 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
