Andersen Double Hinged French Door Problem - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 04:49 PM   #16
MAS
Thanks Russ! I'll do some of my own research and if I find anything I'll let you know.
MAS is offline   Reply With Quote
Old 05-03-2009, 08:50 PM   #17
Rewards Points: 91
Originally Posted by MatadorMkV View Post
I also thought about trying other companies that use the same type of "centering" mechanism to try for a spring.
If you look carefully, you'll see that there really are very few unique mechanisms in the marketplace. Take a close look at your lockset and go to Rona/Home Depot/Lowes etc and look at each of the locksets on display. You may just find your lockset, slightly modified, under a different brandname/model number. This will take research. Look for common points on the outside of the lockset. Look for common size, features, protrusions, anything that might betray the contents of the package.
I've found this to be true on many products. Products made by a Taiwan firm carrying as many as 7 brand names in North America (Ridgid, Delta, Jet, BusyBee, SteelCity, Grizzley, King...).
Hope this helps.
Allthunbs
Allthunbs is offline   Reply With Quote
Old 05-03-2009, 10:27 PM   #18
Rewards Points: 5,336
If you have a broken spring, why not look for companies that make springs? If I need a bearing for a craftsman shop vac, I go to a bearing company.
Ron
Old 06-03-2009, 08:59 PM   #19
Anderson French Door Replacement Spring
Hey Guys,
I also have a problem with an Anderson Frenchwood door. The handle drops down and won't stay up. I took the whole thing apart to find that there is a small torsion spring inside the lock mechanism that broke. I called Anderson for a replacement spring...which should be like maybe a buck...and they said I have to purchase the entire mechanism for $172.00!! I'm thinking about looking around at hardware stores or even calling a spring company, but does anyone know off hand where I can find one?
Thanks,
Russ
Hi Russ,
I found a supplier for the replacement Anderson Door spring and have a number of them for sale. If you or anyone are interested in purchasing one, please send me an email at budscarp@aol.com and I'll ship one out to you ASAP. 6-3-09
Charles Baker is offline   Reply With Quote
Old 10-10-2013, 09:34 PM   #20
Any solutions to this problem?
I know this thread is over four years old, but does anyone know where I can get a spring for the door handle or another solution?
Jiml9 is offline   Reply With Quote
Old 04-17-2015, 08:10 PM   #21
Rewards Points: 2
Question
Spring for Fruitwood Andersen broken lockset spring
Has anyone been able to find a replacement spring for the 7174A-41 Multipoint lockset? I noticed eBay has numerous vendors seeing various springs compression, but I lost the broken spring and don't have the dimensions of the needed replacement spring. I too have contacted Andersen and the want to sell the entire lockset for $172., which is too rich for my blood, seeing all I need is a one dollar spring.
rodie is offline   Reply With Quote
Old 06-22-2015, 11:48 AM   #22
Rewards Points: 2
i am having the exact same problem with my torsion spring. it is very accessable to replace but can't get the spring from andersen. spring $1.00 vs door lock mechanism $181.00. any help on locating a spring would be very helpful
bobbyadle is offline   Reply With Quote
Old 06-22-2015, 06:41 PM   #23
Posting a photo of the spring would help.
I had an issue with the screen latch for the double screen doors on the French doors and just bought a bag of springs from Amazon to replace the broken one.
Ron
B. Franklin 1759
Old 06-05-2016, 07:38 PM   #24
Rewards Points: 2
Re: Andersen Double Hinged French Door Problem
I just had new Anderson exterior french doors installed. One of the doors will not remain open. If you open the door 90 degrees and release your hand from touching the door, the door starts to slowly close. The other side will remains open. Is there any adjustment I can make to resolve this?
Thanks in advance
klamm49 is offline   Reply With Quote
Old 06-05-2016, 08:30 PM   #25
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Thanks in advance
You may get more response if you start a new thread, this one is old.
If your door will not stay open chances are the wall is out of plumb. You can make the door stay in one spot if you take the hinge pins out and bend them slightly. If it still doesn't stay open bend the pins a little more.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
klamm49 (06-05-2016)
Andersen French Door-rattles sjatm05 Building & Construction 2 11-16-2008 03:28 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
How much clearance do I need between double french doors? SnowDrops Carpentry 12 11-29-2007 09:54 AM
