Anchoring To Steel Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 10:31 PM   #1
Anchoring to steel studs
Im trying to anchor a 4x4 aprox. 8' long to steel studs but also need it to look professional and have minimal bulk, for instance if there was some sort of red head or hilti bolt make for anchoring into steel studs, and i need it to withstand quite a bit of weight, any ideas on how to anchor into the steel studs
JPrachnick is offline   Reply With Quote
Old 11-18-2010, 11:00 PM   #2
Rewards Points: 558
Well the only way I would do it would be either using 1/2'' dia. carriage bolts or through bolts with nuts and washers.
1) Drill a 5/8'' hole into the steel studs aprox 16'' o/c
2) Place the 4x4 next to the stud, clamp it and drill through the steel stud and 4x4 with 5/8'' bit.
3) place either the carriage bolt or through bolt through the hole and tighten with nut and washer.
4) Thats the way we do it.
epson is offline   Reply With Quote
Old 11-19-2010, 08:26 AM   #3
Rewards Points: 1,528
What gauge are the steel studs? What do you mean by having to hold a lot of weight? If these are the studs used for sheetrock walls, you may have an issue with the steel stud support failing.
bob22 is offline   Reply With Quote
Old 11-19-2010, 03:31 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... I Agree with That....
Steel stud framing that I've worked with in some places is just about strong enough to hold up it's drywall, 'n Little More...
Old 11-19-2010, 08:16 PM   #5
Drywall contractor
Rewards Points: 1,070
The proper way would be to put wood blocking between the studs and fasten to the wood, NOT the metal studs (especially since they're likely a light, non-load bearing gauge).
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
JPrachnick (11-23-2010)
Old 11-19-2010, 09:05 PM   #6
Metal studs are the perfect application for toggle bolts.
Lockeset is offline   Reply With Quote
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Boxing beams and ducts with steel studs Chemist1961 Building & Construction 3 06-15-2009 10:55 AM
ENT in steel studs? krazni Electrical 4 01-15-2009 02:04 AM
insulating between steel studs drewhart Building & Construction 1 09-05-2008 09:07 AM
Steel Studs ? Steve Carpentry 3 11-24-2006 06:10 AM
