Anchoring Sill Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2013, 03:26 PM   #1
Rewards Points: 91
Anchoring Sill plate
Need some help . I have a 24x24 pole barn with a 4 inch slab. Going to enclose and add garage doors. I know I need a PT sill plate to which I attach studs 16 on center. Will than use Hardi board etc.
I checked codes and want to do a good and safe job. Not concerned with inspection as this is a DIY. Please no lectures.
Code states anchor should be 7 inches into concrete or equivalent.
I was going to use the Simpson threaded anchors which you hammer into a hole and than thread nut over sill plate and tighten down.
Since slab is only 4 inches do I use a 2 or 3 inch anchor or better to find a toggle type bolt and go through the slab? I am also concerned about possibly cracking the slab as the hole will only be about 2 inches from edge.
Any help is appreciated.
drjay9051 is offline   Reply With Quote
Old 08-27-2013, 03:54 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
in that case i would use a 5/8 " threaded rod and two part epoxy, drill out a 5/8" hole into the slab 4" down and have the rod stick out 2 1/2" from the slab
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (08-27-2013)
Old 08-27-2013, 04:00 PM   #3
Bill Kearney
Rewards Points: 1,174
DIY doesn't magically exempt you from needing a permit and inspections. Just know jobs done without them and found to not meet code are quite often required to be torn down. So following code is a good plan.
I'd go with the epoxied rod.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
woodworkbykirk (08-28-2013)
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
Rotted sill plate and broken joist repair netlinks Building & Construction 6 07-17-2012 10:27 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 09:11 AM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 03:07 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
