-   -   Anchoring Sill plate (http://www.diychatroom.com/f19/anchoring-sill-plate-186056/)
drjay9051 08-27-2013 03:26 PM
Need some help . I have a 24x24 pole barn with a 4 inch slab. Going to enclose and add garage doors. I know I need a PT sill plate to which I attach studs 16 on center. Will than use Hardi board etc.
I checked codes and want to do a good and safe job. Not concerned with inspection as this is a DIY. Please no lectures.
Code states anchor should be 7 inches into concrete or equivalent.
I was going to use the Simpson threaded anchors which you hammer into a hole and than thread nut over sill plate and tighten down.
Since slab is only 4 inches do I use a 2 or 3 inch anchor or better to find a toggle type bolt and go through the slab? I am also concerned about possibly cracking the slab as the hole will only be about 2 inches from edge.
Any help is appreciated.
woodworkbykirk 08-27-2013 03:54 PM
in that case i would use a 5/8 " threaded rod and two part epoxy, drill out a 5/8" hole into the slab 4" down and have the rod stick out 2 1/2" from the slab
wkearney99 08-27-2013 04:00 PM
DIY doesn't magically exempt you from needing a permit and inspections. Just know jobs done without them and found to not meet code are quite often required to be torn down. So following code is a good plan.
I'd go with the epoxied rod.
