Anchoring PT 2x4 Sole Plates Into Concrete For A Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 01:38 PM   #1
Rewards Points: 1,062
Question
anchoring PT 2x4 sole plates into concrete for a shed
hi, i am just about to set the frame for me 11x9 shed into its concrete foundation. i was gonna use 1/2x8 decking bolts ($2.79 each, ouch!). was wondering how many bolts i should use on each plate, i.e. how spread apart they should be. my gut feeling was about 4 on each side spaced evenly, will that be OK or should i use more?
thanks
Old 12-30-2010, 01:55 PM   #2
Rewards Points: 5,336
You don't need 8" long bolts for this. 6" is more then enough. Putting the number of bolts that you planned is fine.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
amakarevic (12-30-2010)
Old 12-30-2010, 02:01 PM   #3
Exclamation
i think 8 and 10 was all they had at HD but i will look again more closely on my next trip in a couple hours.
thanks, Ron
Old 12-30-2010, 02:14 PM   #4
thanks, Ron
Go into the fastener aisle and look for wedge anchors.
Ron
Old 12-30-2010, 03:00 PM   #5
What is the code for spacing anchor bolts? I live in Ca. earthquack country, is the code different here?
NASCAR9 is offline   Reply With Quote
Old 12-31-2010, 12:45 PM   #6
Question
Ron - they are actually 1/2x6, my bad. Next question (see my other thread): which size SDS-plus drill bit should I use for the hole in concrete, 5/8 (snug) or 3/4 (les snug) or else, considering that I will be fastening them with anchoring epoxy ? I would experiment with different drill bits but they are really expensive ($25) and I just really wanna buy the one that's perfect for this application.
Old 12-31-2010, 12:59 PM   #7
The code will be different there. Contact the local office.
Ron
Old 12-31-2010, 02:26 PM   #8
Question
hey Ron, did you see my last inquiry ? i'm sure it's a no brainer for you... thanks ...
Old 12-31-2010, 03:17 PM   #9
I've never used an epoxy secured bolt. It's either been anchored in the foundation wall or a wedge anchor.
From a common sense approach it would seem the 5/8" hole wouldn't hold enough epoxy around the perimeter of the bolt shaft to secure it properly.
Ron
Old 12-31-2010, 06:13 PM   #10
Registered User
Rewards Points: 526
Here is an older one, just search Google; http://docs.google.com/viewer?a=v&q=...h1W5lElSFXE4_w
Amak, if you live in Fl or the Gulf Coast, contact your local B.D., as the Codes are stricter for sheds due to winds.
Gary
Old 12-31-2010, 07:05 PM   #11
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
NORMAL drill size for using epoxy with a 1/2" bold is 9/16" hole. Every epoxy manufacturer has there own requirements, so follow the directions. More and bigger aren't always better and stronger. You usually want the hole as small as possible
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Anchoring A/C unit to concrete JNeu HVAC 5 10-21-2010 07:31 PM
anchoring concrete stairs to the house amakarevic Building & Construction 2 06-14-2010 03:25 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
power-actuated nail size for sole plates amakarevic Building & Construction 4 06-03-2008 01:12 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
