Anchoring Furring Strips Into Old Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 09:39 PM   #1
Anchoring furring strips into old brick
I need to anchor furring strips into very old spalling brick and masonry (circa 1870) so I can place board and batten and insulation over it. I am concerned that Tapcons in the old masonry won't hold and also that the brick veneer itself is not well attached to the sheathing/studs underneath. Should I take the old brick wall down?
NRKW is offline   Reply With Quote
Old 07-05-2011, 09:54 PM   #2
Rewards Points: 558
How lose is the brick?
epson is offline   Reply With Quote
Old 07-06-2011, 08:34 AM   #3
Too Short? Cut it Again!
Liquid nails or other construction adhesive could work if all you are putting on it is insulation and material to hold it in place.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Attaching 12/2 wire to Furring Strips blaze01 Electrical 2 02-17-2010 02:17 PM
Furring strips on peaked roof zantar Building & Construction 6 11-18-2009 10:46 AM
anchoring door in a brick and concrete wall agroux Carpentry 1 05-08-2008 01:28 AM
