Anchoring 4x4 Into Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 02:08 AM   #1
Anchoring 4x4 into cement
Were in the process of building a handicap ramp. The ramp area is all located on concrete that was already done long ago. The only parts were anchoring into the cement is the posts closest to the door. We drilled the holes and when we tried to get the bolts inplace most of them went in fine but I applied to much pressure to one of them and snapped the bolt head right off and the other one would only go so far before it just woulden't sink in any further and it woulden't back out either.
Needless to say it's not SUPER sturdy but it isn't wobbly right now either and it will for sure not be wobbly when the rest of the ramp is together. But we were thinking since they didn't anchor in as well as we would have hoped. We have concrete on hand since were getting ready to install a fence. Would it be a feasable option to put up a small frame around the 4x4's and filling it with concrete so that the anchor hardware and 4x4 get cemented as 1 semi big block? I would think it would adhere to the already poured concrete that way as well and make it more sturdy....
Thoughts? Thanks!
Mstrenke is offline   Reply With Quote
Old 06-25-2012, 08:01 AM   #2
Rewards Points: 13,300
Post a picture.
No one here know what it is your using to attach these post to the concrete.
You say the bolt head snapped off but what were you inserting the bolt into?
http://strongtie.com/products/connectors/ABW.asp
A post base like this would have worked
With a lead anchor and a lag to hold it in place.
http://strongtie.com/products/anchor...l?source=asnav
What's going to keep the post from swaying would be a wide enough header attached to the two post that you can get 2, lag bolts into on each side.
AGWhitehouse (06-25-2012)
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
flat cement roof naturallight Roofing/Siding 7 05-11-2012 10:25 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 02:31 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
