Anchor In Rigid Foam Insulated Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 02:32 PM   #1
Anchor in rigid foam insulated wall
I need to anchor a heavy duty shelf into a basement wall. The wall has 2in rigid foam insulation, moisture barrier, and drywall finish, but I am not sure of the details of the framing. The studs appear to be 24in apart, but covered on the inside with one layer of the foam (this is not as it is supposed to be, but it's the way it is around one power outlet). So the studs are some 3in below the surface. Any ideas how to anchor into such a wall? Would the furring strips suffice (assuming I can locate any)?
imjoking is offline   Reply With Quote
Old 10-15-2011, 10:27 PM   #2
Rewards Points: 5,334
I doubt it. The bite will be 3" in. The weight will be far outside the wall. The only thing holding it up is foam and drywall. I think you would need a support under the shelf, like an "L" bracket with a diagonal brace.
Ron
B. Franklin 1759
Old 10-17-2011, 09:53 PM   #3
Just to clear things up, Martin, yes the normal installation is to press the thin stone veneer into a wet scratch coat. The only thing complicating that is the foam layer. Hence the suggestion for something extra for the stone to bear on.
How much veneer are you installing? is it like a 12 foot high wall, or just a foot or two down by the foundation?
Regards
Chantell Wilson
ChantellWilson is offline   Reply With Quote
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
expanding foam vs cutting sheets of rigid foam for rim joists Red Squirrel Building & Construction 15 11-23-2010 11:46 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 12:41 AM
