Anchor 4x4 Post To Cement Pier - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 08:02 AM   #16
Anchor 4x4 Post to Cement Pier
Originally Posted by cortell View Post
However, it's much better to just extend the pier to above ground at least 4 inches.
So maybe extend the pier about 9 or 10 inches. Do you think this would work if I drill some holes in the existing pier, rebar it, and use a bonding agent?
ulrichfolkers is offline   Reply With Quote
Old 05-09-2012, 08:46 AM   #17
cortell's Avatar
Rewards Points: 504
That's what I would do. As a bonus, you can go with a wet post base connector.
cortell is offline   Reply With Quote
Old 05-09-2012, 09:00 AM   #18
This is looking like a better idea than going the below grade route.
Old 05-09-2012, 12:18 PM   #19
Is it ok to Just pour on top of his exsisting pier ?
illnastyimpreza is offline   Reply With Quote
Old 05-09-2012, 12:25 PM   #20
cortell's Avatar
Rewards Points: 504
It is not ok to just pour. The new section has to be tied into the existing, which is where the rebar comes in.
Post N Pier Foundation question. deck99 Building & Construction 9 03-05-2013 05:21 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
post and pier foundation and veneer? wombosi Building & Construction 1 07-21-2010 07:33 PM
Post and pier addition to house with block foundation? Badfish740 Building & Construction 5 07-08-2010 08:14 PM
post and pier repair question tcameron Building & Construction 6 11-14-2007 07:07 PM
