Aluminum Trim Falling Off My House! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 08:38 AM   #1
Question
Aluminum trim falling off my house!
My house has vinyl siding with aluminum trim up by the roof line. Every spring I have had pieces of aluminum trim that wrap around a corner just fall off the house... and usually with a nail still piercing the metal. How should I fix this so my house dosen't shed any more siding in the spring?
-Thanks,
SE
clueless19 is offline   Reply With Quote
Old 05-04-2009, 08:50 AM   #2
the Musigician
DangerMouse's Avatar
hi and welcome to the forum.
it sounds to me like you may be getting wet under the fascia (aluminum trim) and the smooth nails they used to mount it are sliding out.
if not wet, then even wind can pull a 1" smooth nail.
(i had the lumberyard send me white fascia nails once and that's what they sent)
is there a drip edge that the fascia piece slides under at the roof edge?
i'd probably just use a longer ringshank or twist nail and then paint the heads white to hide them.
DM
Old 05-04-2009, 09:38 AM   #3
As far as I can tell there is nothing that it slides under. Thanks for your response and I will try your suggestions soon!
- SE
Old 05-04-2009, 10:44 AM   #4
Rewards Points: 5,336
-Thanks,
SE
Check to see the wood that supposed to hold the nail is solid. If it's soft or rotted, replace it and follow DM"s advice about the correct nails to use.
I would also go around and renail all the fascia now with the new nails to eliminate doing it again next Spring.
Ron
Old 05-04-2009, 11:18 AM   #5
the Musigician
good point Ron....
hmmm.... no drip edge? do you have a picture of what you have there?
you might want to add a drip edge while you're up there.......
DM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Old house new problems: I need advice SandyD Building & Construction 3 09-14-2007 11:53 PM
