Old 08-02-2008, 07:44 PM   #1
Aluminum solar panel frame ideas wanted
I'm wanting to build an aluminum solar panel frame and need some ideas.
Below is a solar panel made of wood, if only I could make one out of aluminum channel with a glass top or knew someone who could make this for me or tell me how.
If anyone has an idea on how to do this please e-mail at midwestmeteor@earthlink.net THANK YOU
easytim is offline   Reply With Quote
Old 08-03-2008, 10:01 AM   #2
Eibwen
I would check with some local home improvement contractors that do patio door replacements....
One panel of an old sliding patio door would make a nice top for that.
Just make sure its not Low E coated or it may reduce you cell production.
Sammy is offline   Reply With Quote
Old 08-03-2008, 10:36 AM   #3
It was a dark and stormy
Yoyizit's Avatar
How rigid does the support panel have to be to avoid damaging the solar panel due temp. expansion and contraction and normal handling?
Old 08-03-2008, 12:01 PM   #4
Just enough so it won't bend, I would leave 1/4 in for movement
Old 08-03-2008, 12:02 PM   #5
Thanks Sammy great idea
Old 08-03-2008, 03:40 PM   #6
Eibwen
Your welcome
They make good cold frames too for starting new plants in the spring if you do any gardening.
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Solar panel for koi pond pump? Badfish740 Electrical 5 02-29-2008 05:29 AM
