Old 12-16-2006, 04:27 PM   #1
Question
Aluminum Soffit and Fascia Installation...
Does anyone have any good information as far as aluminum soffit and fascia installation goes?
The product that I am using is Sell-Even. I'm not new to soffit and fascia installation however I am new to the aluminum soffit and fascia installation. I've got a 24X24 foot gable end garagee that I am currently working on. They do have a small installation guide.
http://www.appletonsupply.com/graphi...20yourself.pdf
For one thing I'm slighlty confused how to box in the gable ends at each of the corners for the installation. According to the installation instructions I can not do it in the same way as the house currently is.
Most I have seen appear to look like the picture below. I'm not sure if I could even do it the other way, it seems like there could be a problem where everythigng came together if I did.
This would be opposite of the way that the house is, however the house was done with conventional wood soffit and fascia.
I've looked at the Reader's Digest install guide which does have some helpful tips, however I can't seem to find a detailed install manual.
Any help or tips would be appreciated.
Thanks, Adam
MoparAutoworks is offline   Reply With Quote
Old 12-17-2006, 08:46 AM   #2
You would need a break to bend the soffit panel ant the angle required to make the box end
sjrhome is offline   Reply With Quote
More On This Topic
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The shake panels are terminated by bending over the gable fascia at approximately 2 inches. Place the shake cap over the gable aligning a profile in... Read More »
Water damage can cause all kinds of problems for your home, but you can help prevent it if you buy the right type of fascia. While all types of fascia can function equally well, maintenance and cosmetic differences can help guide your decision. Read More »
Fiber cement fascia boards provide the same water protection as other materials but offer increased options for finishes. Since fiber cement tends to be more expensive than other types of fascia, you need to take greater care when you install it. Read More »
How to Frame the Roof Ridge
How to Frame the Roof Ridge by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Where the ridge is to be ventilated and the coursing is less than a full tile, a one inch board is laid parallel with the ridge on each side... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Barrel cap trim is installed from the bottom up course to course with the panels. Install the end disc, position the first cap on the rig with the rear... Read More »
Fascia & soffit help MIKEGOUGH1 Building & Construction 1 01-20-2007 01:29 PM
fascia and drip edge glassman General Discussion 3 10-02-2006 07:39 PM
Where do I nail Aluminum Fascia? irlizard Roofing 5 08-05-2006 03:49 AM
Soffit installation question milano Roofing 4 02-04-2006 11:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
