Aluminum Siding Scrap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 12:47 PM   #1
aluminum siding scrap
We have aprox 2000 aq ft house with aluminum siding that I am removing and scrapping. Our local scrap yard gives .62 a pound. How much do you think I will get total for all my old siding.
Jbyrd is offline   Reply With Quote
Old 04-01-2011, 12:58 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,346
Assumptions:
1/3 lb/foot^2
Foot print 25x40
2 levels
$483
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-01-2011, 08:10 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'll bet that price may be for #1 scrap aluminum. Is aluminum siding considered #1 scrap? Maybe not. Might be worth closer to 15 cents. It would be interesting to know what you find out.
XXX
Old 04-01-2011, 08:52 PM   #4
I called and asked them if they took scrap aluminum siding and they said yes and they pay .62 a pound. I even said to them .52 a pound and they said no .62 a pound.
Old 04-01-2011, 10:31 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
your number is correct it's 70c a pound here...for now
copper is around 3$
Tom Struble is offline   Reply With Quote
Old 04-02-2011, 05:07 AM   #6
kwikfishron's Avatar
Rewards Points: 430
That price sounds about right. If you have other yards in the area call them too.
That business is highly competitive and prices due vary.
kwikfishron is online now   Reply With Quote
Old 04-04-2011, 10:00 PM   #7
After scraping a 12x13 wall, 20x6, and a 24X4 walls of siding I had 222 lbs. $133 dollars worth. Needless to say I was very happy.
Old 04-04-2011, 10:33 PM   #8
Rewards Points: 84
Last year one day, I was cleaning up inside the barn, and decided to load up the back of the pickup with scrap steel. As I started off to the scrap yard the next morning, I happened to recall one small box of scrap aluminum that I had tossed up in the loft, and had forgotten to take before, so went back to get it, and sat it on the seat beside me. Lo and behold, I ran across the scales, unloaded the steel, ran over the scales again, walked in with that box of aluminum under my arm, and walked out with more money for the aluminum than for something like 1,500 lbs. of steel. No real surprise, but that trip sure drove the point home.
Old 04-05-2011, 01:23 PM   #9
little known fact,the Washington monument is capped with a small pyramid of pure aluminum which at the time was more valuable than gold or platinum
Nothing Under Aluminum Siding dkel22 General DIY Discussions 9 09-30-2009 03:40 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
