Aluminum Siding Over Existing Old Wood Siding. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 12:15 PM   #1
Aluminum siding over existing old wood siding.
Hi all,
my wife and I installed a sliding glass door at the back of our house last weekend. We had to cut out a section of the back wall and aluminum siding out back. The door slid in like butter, but now it is time to put the aluminum siding back (resized of course) over the excess that we took out.
The siding was nailed into the old wood siding (ours is an OLD house), and had a cork like board over the old wood slants to act as buffer and make the surface even. We are a bit confused - what would be the best way to put the aluminum siding pieces back? What should we put over the wood slants to make the surface even - we threw away the buffer board bits, so can't actually restore the pieces of the same. And once we get the siding up, how to seal up the corner to make it water tight?
Thanks for any help, first time here and psyched at finding this community.
timothevs is offline   Reply With Quote
Old 04-23-2009, 04:13 PM   #2
"yeah...we do that!!!"
the wj=hole basis for what you are trying to do is get the siding back on
so figure out what the entire thickness of the siding equals to and pack out the missing area with enough material to equal the thickest part of the siding. maybe it's 1 1/2" or 3/4" whatever nail the stuff on and reapply all the siding
one more thing tivek house wrap, tarpaper whatever best of all i love to use iceand water shield and flash out the door prior to siding install
good luck
KOHNSTRUCTION is offline   Reply With Quote
aluminum , siding , wood slants
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 09:20 PM
Repairing wood siding next to a door frame... Beth777 General DIY Discussions 7 07-22-2008 08:56 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Cutting Aluminum siding gmjosey Carpentry 3 12-16-2006 10:55 AM
