Aluminum Siding Has Galvanic Reaction? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 12:09 AM   #1
Rewards Points: 682
aluminum siding has galvanic reaction?
Does aluminum siding have a galvanic reaction to iron and galvanized nails or any other metal? Is it long lasting? The stuff I've used seems to be pretty hardy.
darsunt is offline   Reply With Quote
Old 02-21-2012, 12:15 AM   #2
Rewards Points: 13,694
Why are you asking?
Aluminum siding is almost never used anymore for a bunch of reasons.
Old 02-21-2012, 01:29 AM   #3
Rewards Points: 682
I apologize, I mean aluminum flashing.
Old 02-21-2012, 06:46 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
aluminum flashing is used quite steadily both in renovatins and new construction today. when i install it i use either aluminum or stainless steel painted ring nails. roofing nails work fine also
the key thing to avoid is having it contact with pressure treated lumber as the chemicals in the wood will turn the aluminum to ash. most contractors use aluminum to flash deck ledgers however they dont do anything to keep the aluminum out of contact with the pt wood. i run a strip of 4" vycor or blueskin along the top of the entire ledger which stops the aluminum from touching the wood
woodworkbykirk is offline   Reply With Quote
Old 02-21-2012, 08:21 PM   #5
The table at the bottom tells you how much voltage difference you can tolerate in the presence of moisture
http://en.wikipedia.org/wiki/Galvanic_corrosion
Old 02-22-2012, 08:30 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Keep copper products (including Modern Pressure Treated Lumber) away from aluminum. Also, if working with concrete & masonry - use lead flashing.
- Build Well -
Old 02-22-2012, 10:31 PM   #7
Rewards Points: 682
So don't use it around concrete/fiberglass floor membranes?
Aluminum siding not matching after Door install alcopaulic Building & Construction 1 09-07-2011 08:46 PM
Nothing Under Aluminum Siding dkel22 General DIY Discussions 9 09-30-2009 03:40 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
