Old 01-24-2010, 03:56 PM   #1
aluminum siding fix
I've got old aluminum siding on a house - was hoping to get two more years out of it. Recently, however, I discovered a place where it's exposing exterior wall plywood. It's where the siding meets with an older wall that is cynder block.
Pic attached. (Wood grain to the right is just a fence post)
Any tips on sealing this up to keep it dry for 18 months to 2 years?
atlzim is offline   Reply With Quote
Old 01-24-2010, 05:50 PM   #2
firehawkmph's Avatar
aluminum siding fix
no pics,
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-24-2010, 08:53 PM   #3
aluminum siding fix
thanks! Now attached.
Old 01-24-2010, 09:13 PM   #4
aluminum siding fix
You could use some of the window and door sealing foam (minimal expanding) for the larger gaps, then caulk the rest with a good grade caulking. Check it periodically to make sure the caulk hasn't shrunk or pulled away.
Mike Hawkins
Nothing Under Aluminum Siding dkel22 General Discussion 9 09-30-2009 04:40 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
