Old 11-14-2012, 07:46 PM   #1
Aluminum siding corners
These corner pieces CONSTANTLY come off so to get ready for a refi appraisal I'm gonna nail most of these on for good.
I'm planning to use a nailer but am not sure what nails to use.
Shingle nail? Roofing nail?
Do either come in packs for nailers?
Zamboknee is offline   Reply With Quote
Old 11-14-2012, 07:58 PM   #2
Moderator
kwikfishron's Avatar
I can’t imagine how an aluminum siding corner could fall off.
Are you talking about a wood corner wrapped in aluminum?
Pictures would help.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 11-14-2012, 08:58 PM   #3
May be the small corners that used to be used long ago on Masonite type siding.
If you use use trim nails. There sold in the siding area. There going to be aluminum. The better ones are stainless steel but for some reason the box stores in most cases do not carry them.
Old 11-14-2012, 09:48 PM   #4
Moderator
That make sense, I wasn't thinking about those. They're fastened at the top where the next coarse would hide the nail.
I'd probably glue those things back. You wouldn't want to face nail them.
Maybe a trim nail up under the butt of the siding. If it's hardboard (Masonite) then that nail probably wouldn't stick for long...Back to the glue.
-NEW MEMBERS-
Old 11-14-2012, 10:27 PM   #5
I have used self drilling gutter screws to hold these in place. They come with painted heads!
Old 11-14-2012, 10:36 PM   #6
Not a great look.
Old 11-14-2012, 11:11 PM   #7
Not a great look.
They are barely noticeable, just under the lip above!
Old 11-14-2012, 11:17 PM   #8
funfool's Avatar
Think I would glue them in place with clear silicone caulk.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
Old 11-15-2012, 07:37 AM   #9
Here's the pic of what I'm talking about.
Sorry, meant to post this with original question.
House was built in 1989 by the way.
Old 11-15-2012, 07:56 AM   #10
Looks like the singing is trying to curl on you which is causing the corner to pop off.
May want to add a siding nail or two to hold the siding in place before reattaching the corner.
Old 11-15-2012, 12:12 PM   #11
so nail the siding down and DON'T put a nail through the corner piece?
Copper roof & aluminum siding Marcia Hamilton Roofing 4 04-24-2012 11:36 PM
where to get aluminum siding?????????? cherry_560sel General Discussion 7 03-02-2011 09:46 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
