Aluminum Sided House To Vinyl Sided Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 11:54 AM   #1
DCC
Aluminum Sided House to Vinyl Sided Addition
I have a 9' X 12' screen porch attached to a 1950's style cape that I'm enclosing. The porch is located on the side of the house, flush with the front. When complete, it will appear that the house has been lengthed by 9'.
The house is aluminum sided. The new vinyl sided matches the aluminum in color (white) and reveal (4"). No problems there.
The issue is mating the aluminum corner channel with vinyl j-channel. Since this is the front of the house and I am not an aluminum siding professional, I do not want to risk damage to siding by removing the corner piece.
I've attached some pictures.
Anyone have any ideas on the best way to do this?
DCC is offline   Reply With Quote
Old 10-26-2008, 12:02 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
if the framing is matched to the existing then I would strip the whole side of the house and reside it with the vinyl. or you could pull off the corner and install an H channel and run your siding into that. being a contractor I would go the first route, it would look much better. BOB
Tags
addition , aluminum , vinyl
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
