Aluminum Over Treated Wood Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 11:38 AM   #1
Post
Aluminum over treated wood problem
Two years ago we had a porch built. The post were built of treated lumber and wrapped in aluminum. Of coarse the post have now pitted and
and holes have appeared. The contrator has removed the aluminum and painted the post and plans on replacing the aluminum within the next day or so. My question is, there is already staining bleeding through the
new paint. Will this cause a problem with the new aluminum? If so , how should it be approached? Thanks.
Lrjkats is offline   Reply With Quote
Old 06-13-2013, 11:42 AM   #2
Rewards Points: 13,300
Why in the world would he put more alumium back on!
Read the box of coil stock in big letters it says not to install on pressure treated wood.
Just painting it will do nothing to protect it. It's still going to corrode where the nails go in.
They make a bunch of differant wrap around post covers out of PVC and fiberglass that should have been used.
Old 06-13-2013, 12:41 PM   #3
Part of the problem is me. I wanted, and still do, 6 or 8 inch square post, that I would not have to paint. I questioned the aluminum over treated wood when it was first installed and was told that I would not have a problem. I had researched and thought I knew what I was talking about, but erred and listened to my contractor. When you speak of wraps, are they the thin paper/plastic type wrap they use to cover outer walls on new construction or is there a certain product that wraps that I should be researching? Thanks
Old 06-13-2013, 12:47 PM   #4
Here a sample of one of the companys that makes them.
http://www.screentight.com/prod-wrapnsnap.shtml
Just google "post wraps" and lots come up.
Lrjkats (06-13-2013)
Old 06-13-2013, 01:42 PM   #5
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I guess I have to wonder why they put sheet metal over treated lumber in the first place...
RWolff is offline   Reply With Quote
Old 06-13-2013, 02:07 PM   #6
I don't know. I checked out the comapny and it had a reputable reputation. Just got off the phone with head honcho and he said he would talk to his installer and see what he thought. Said they had never, ever had this problem.
Old 06-13-2013, 06:35 PM   #7
DIY staff
Rewards Points: 7,174
New formula PT wood ---the old stuff did not eat up aluminum---
Look into Joes suggestions--avoid aluminum---
Old 06-13-2013, 07:44 PM   #8
If he's never seen it then he has not been in business long.
I see it all the time around gargage doors.
Old 06-14-2013, 08:52 AM   #9
Looking into the post wraps that Joe suggested. Now finding the wrap in a color other than white or tan is an issue. I do not want to have to paint the post and since it just a few posts, it would be rather expensive to have them special made in a cream. Going to the box stores today and see what they can do.
Old 06-14-2013, 10:59 PM   #10
DIY staff
Where you want to look is at a roofing and siding supply company----
Old 06-15-2013, 08:11 PM   #11
GBrackins's Avatar
Rewards Points: 2,108
what you have is a case of dissimilar metals. preservative treated wood typically has copper. by nature you'll have a galvanic reaction which will cause the metal to deteriorate.
go with something like pvc or vinyl. there are many wrap options available.
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Regular latex paint on treated lumber zrooster99 Carpentry 3 07-06-2011 02:43 PM
Carpenter bees will infest pressure treated wood downunder Pest Control 0 05-08-2011 12:49 PM
How to disassemble aluminum clad wood window sash? JohnBinSC General DIY Discussions 6 01-17-2011 06:59 AM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Pressure Treated Wood Appearance... Melanie337 Painting 7 08-04-2008 10:51 AM
