Aluminum House Wrap For Ceiling In Warehouse - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 05:24 PM   #1
cutbait
aluminum house wrap for ceiling in warehouse
We are trying to cover a really ugly warehouse ceiling with the cheapest product available. It is about 2500 sq ft of 3/12 pitch ceiling. The 2x8 rafters have bat insulation between rafters and 4'x8'x3/4" foam board nailed to the bottoms. We are not concerned about insulation since this is just a big storeroom. If we could use the single sided aluminum house wrap and tape the seams, it could be done for about $400. My notion is to attach it with plywood staples (adjusted so they don't go too deep). The concern is will this cause sweating and make a big mess. The roof is galvalume. There is no HVAC in the room. If this is a bad idea, can anyone advise another cheap solution. Thanks for input. Jim
cutbait is offline   Reply With Quote
Old 02-16-2013, 05:37 PM   #2
Rewards Points: 13,468
Are you talking about this?
http://www.homedepot.com/webapp/cata...gry=Search+All
Going to be a whole lot more the $400.00 to use that material and it's going to sag between the joist.
If this is a commercial building then I would think you will need to meet fire codes which will require at least one layer of 5/8 fire rock.
Old 02-16-2013, 05:50 PM   #3
cutbait
That is not the material. You can only find this stuff on the internet and is much cheaper. This building would not meet any code and won't require any permit. The only concern is will it sweat.
Old 02-16-2013, 08:24 PM   #4
Rewards Points: 150
A couple of photos will probably enable some good responses. I am not familiar with the product you are using but generally you do not leave foils exposed. Once a foil is burning most burn rapidly. You may wish to check the flame spread rating on the product.
TheCamper is offline   Reply With Quote
Old 02-16-2013, 08:37 PM   #5
cutbait
Good information. I will check out the fire thing and attach a picture tomorrow. Thanks
Old 02-17-2013, 05:19 PM   #6
cutbait
Here's a picture of the ceiling and a piece of the wrap. I notice that it is perforated so maybe this would avoid sweating. This material is really strong and should stretch tight. Data from the various manufacturers seem to brag about fire issues but they aren't discussing this kind of application. I held a match to it for 5 seconds before it started to burn but I think that would be the same with the foam or most other coverings. Is there a flame retardant spray?
Jim
aluminum house wrap for ceiling in warehouse-img_3169.1.jpg   aluminum house wrap for ceiling in warehouse-img_3176.1.jpg
Old 02-17-2013, 06:07 PM   #7
joed's Avatar
Rewards Points: 12,456
What is your question? Are you looking to use this material on the ceiling?
As for fire, foam is required to be covered with a fire barrier like drywall. It can't be left exposed.
Old 02-17-2013, 06:37 PM   #8
cutbait
We are searching for the least expensive product to cover the foam. This building is a mess and building codes are non-existent. We are volunteers doing everything with minimum funds. The foam was there for years before we bought it. Is there a fire retardant that can be sprayed on the wrap?
Old 02-17-2013, 07:12 PM   #9
To ansewer your question, the ansewer is no.
Old 02-17-2013, 07:21 PM   #10
cutbait
Suggestions anybody for inexpensive ceiling finish? Should we take down the foam and leave the insulation exposed or take it all down?
Old 02-17-2013, 09:42 PM   #11
Rewards Points: 150
If labor is not a factor (volunteers doing the labor) I suggest removing the foam and installing gypsum board, preferably 5/8" type X, if it is in the budget. I am uncomfortable with leaving any foil exposed. My other suggestion is that if the building is a free standing building and off the lot lines, where it does not require a fire rating, and you are not heating it, then gut it to the frame and leave it open.
Old 02-17-2013, 09:47 PM   #12
cutbait
Thanks for the input guys. I think we will strip it down. Jim
Tyvek, Generic House Wrap, Roofing Felt, or? Earnie Building & Construction 22 10-17-2012 10:58 AM
House wrap meets brick house question joshv Building & Construction 5 09-15-2012 09:26 AM
Aluminum window wrap lindy617 Windows and Doors 1 09-10-2012 09:24 PM
Aluminum Wiring House Selena Electrical 4 03-10-2010 09:45 PM
Partial House Wrap Bill46 Building & Construction 7 01-23-2006 03:41 PM
