Aluminum Fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 03:39 PM   #1
Aluminum fascia
I finished the new vinyl siding and aluminum soffit / fascia on my garage last fall and will soon begin the house. I am now noticing the fascia on the garage is starting to warp consideraby with the heat. I am assuming driving the nails in too deep is causing this. The other thing is the existing 1x6 wood fascia is tremendously uneven, in the fact that if you look at the bottom edge ( toward the ground ) from 40 feet or so away you can visually tell its up / down like a roller coaster track. Any tips on working with this stuff ?
SAGENT is offline   Reply With Quote
Old 05-12-2009, 06:11 AM   #2
The aluminum expands faster than the wood it is nailed to. Fewer nails usually help the problem, but not so few that wind will blow it off. A dab of silicone caulk will allow it to breath and add some holding power
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 9 08-08-2013 04:40 PM
Nailing up aluminum fascia cover pstasuik Roofing/Siding 8 03-19-2009 03:53 PM
Aluminum fascia wbeannn Building & Construction 6 11-07-2008 06:42 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
