Aluminum Coil Is Disintegrading - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-30-2008, 10:49 AM   #1
aluminum coil is disintegrading
My contractor built a screened porch and put aluminum coil stock over pressure treated wood. Now it is disintegrating. From what I can figure out, he did something wrong in the application on the coil stock. He is willing to fix, but we're not sure how to go about this? He says that the original coil stock was painted on the inside, and this should have prevented the deterioration, but apparently in being bent, some of the paint seal was broken, thus leading to corrosion. Does this make sense? How do we go about replacing the areas that have corroded and prevent further corrosion short of ripping it all out and starting over? I'm not looking to place blame at this point, I just want the porch fixed!
gilbert123 is offline   Reply With Quote
Old 09-30-2008, 11:10 AM   #2
The chemicals in PT wood are toxic and don't get along with other metals well at all.
Putting 2 layers of roofing felt between metal and PT has always worked for me.
Marvin Gardens is offline   Reply With Quote
Old 09-30-2008, 11:19 AM   #3
the Musigician
DangerMouse's Avatar
i'll be doing the same thing soon, would 50m poly work the same? (i have a huge roll) or Tyvek?
DM
Old 09-30-2008, 01:40 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
The increased amount of copper in the newer ACQ treated lumber reacts with aluminum. The aluminum comes out the loser. You can use vinyl coil stock which is kind of a paint to work with. I've seen recommendations for installing a double layer of 6mil poly between the aluminum and the treated lumber. Make sure the builder used the proper fasteners and fittings for ACQ lumber too. It will destroy electro-plated galvanized screws and hangers too.
Old 09-30-2008, 02:25 PM   #5
DM
I wouldn't use tyvek. Too flimsy. Need some bulk.
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
Coil Aluminum murray11 General DIY Discussions 2 06-17-2006 01:42 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
