Aluminum Casing On Front Porch Pillars - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 04:46 PM   #1
Lightbulb
Aluminum Casing on Front Porch Pillars
So I have 4 pillars on my front porch. These pillars seem to have an aluminum decorative casing around the 4x4 which I assume is under them. My question is, How do I remove the aluminum casing? There is a peice on the bottom and top that will slide up and down, but the main casing peice goes all the way to the floor and all the way up to the porch roof. There are two seams on either side of the casing as well. I would assume they would be some type of tongue and groove. But I just can't seem to figure out how to remove the casing. Anybody have any ideas? Let me know if you need pictures.
DRoby is offline   Reply With Quote
Old 09-06-2009, 06:13 PM   #2
Rewards Points: 163
Dont assume there is a 4x4 under them. They sound like aluminum columns. They are probably hollow. Make sure you support the roof before you try to remove them
paul100 is offline   Reply With Quote
Tags
columns , pillars , posts
Help with front porch kchopper Building & Construction 9 07-27-2009 06:44 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
