Aluminum Beam Span For Arbor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 03:45 AM   #1
Rewards Points: 16
Aluminum beam span for arbor
We are building a new patio and covering it with an aluminum arbor. The arbor will cover the patio in 2 sections:
-- A-frame section 20' long by 14' wide
-- Flat section 20' long by 38' wide, with a caveat: there is a Sago palm in the corner of the area that we don’t want to cover, about 5'x5'.
I already know that I can span the 20' from the house to the edge of the patio. I am building seating along the 38' long edge. I need to allow for posts in the concrete to support the beams that will hold up the arbor.
I don’t want to put a post in front of the seating area. If the post will be placed behind the seating area, then I need to pour concrete in that spot. Or I can position the seating between the posts. I just need to know if there is an optimum span for posts over a 38’ long span. Should I plan on four posts about 8' apart? Or can I go longer, for example, two posts 16' apart?
Thanks for any help you can offer.
Brian
btphelps is offline   Reply With Quote
Tags
aluminum , arbor , patio cover , span
Beam Replacement Popeye42 Carpentry 4 12-23-2010 10:29 AM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
