Alum Cap Over Old Wood Drip Cap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:31 PM   #1
Alum cap over old wood drip cap?
Hi all. Hoping someone can help me. I resided my house and had the wood window and door trim capped with aluminum for maintenance. My windows have a wood drip cap at the top (like a top sill) that extends beyond the window trim about 1" on each side. This was capped as well, but there's a problem for water infiltration at the "ears" that stick out (they were sawcut on the ends to let water drain behind). Anybody willing to take a look for any ideas? The sawcut appears to allow for water to drain into the J-channel below, but the water must pass over the sawcut wood first. Perhaps a seam of sealant over the wood would protect the wood from moisture.
cfordnj is offline   Reply With Quote
Old 01-07-2009, 11:49 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
sorry no caulk is going to help thatYour going to have to pull the panel and reflash properly
Tom Struble is offline   Reply With Quote
Old 01-08-2009, 12:03 AM   #3
Thanks. The old wood dripcaps make for a bad situation but the original details were important. Redoing the whole job is not an option financially. (at least not for a while...) Is there another way to address these ends without tearing it all off?
Old 01-08-2009, 12:22 AM   #4
not necessarily ripped out but definitely detailed better
Tags
aluminum capping , break metal , siding , window capping
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
