Alternatives To Using Wood Structural Members In A Brick Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 01:19 PM   #1
Alternatives to using wood structural members in a brick building
Hi,
I own a 3 floor semi detached brick building. Even though the building is solid masonry, all the joists are made of wood(and are over 100 years old) I'm planning the 1st floor apt remodel and since the joists are pretty old, they might need to be replaced. Since it's highly unorthodox to use anything but wood in US residential construction, I'm curious about what the alternatives might be?
One thing that comes to mind is steel beams with steel decking with poured concrete over it. Does anyone have any experience with that? Is it much more expensive than wood?
What are some other alternatives?
vvzz is offline   Reply With Quote
Old 04-25-2011, 02:16 PM   #2
Rewards Points: 582
Beam and block flooring is becoming popular here for newbuilds, although I think I would stick with timber for your house.
Alternatives to using wood structural members in a brick building-technical_diagram.jpg
stuart45 is offline   Reply With Quote
Old 04-25-2011, 09:04 PM   #3
Originally Posted by vvzz View Post
Hi,
Unlees you have pest or water problems, the wood will likely last another 100 years. I just moved from a house such as you describe and the wood was as good as the day it was installed.
Old 05-03-2011, 03:34 PM   #4
I just personally hate the practice of using wood as a structural material. In my opinion houses should be masonry, steel, concrete and not wood.
Old 05-03-2011, 05:21 PM   #5
Civil Engineer
Rewards Points: 4,792
Structural steel is commonly used in commercial/industrial construction. Prestressed or post-tensioned concrete planks are often used in commercial/residential construction, and occasionally in residential construction. Cast in place concrete floors are very commonly used in commercial/industrial construction.
As for costs, it is not possible to make an intelligent statement on costs for a specific project without knowing the details of the project. You may want to consult with an architect, engineer, contractor or cost estimator to evaluate the costs of various alternatives.
Daniel Holzman is online now   Reply With Quote
Old 05-03-2011, 06:52 PM   #6
Maybe so, so but most us couldn't afford to live in such a home.
Homes in Europe have been built from masonry products for century's, but they have started to build wood framed homes because they are more cost effective.
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 11:24 AM
Finding a suitable flooring material for Wood frame Condo building lsgko Flooring 1 02-20-2009 02:38 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Building A New Brick Porch Jerry1122 Building & Construction 3 07-10-2008 03:33 PM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
