Alternatives To Fiberglass Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 02:22 PM   #1
jbk
Rewards Points: 22
Alternatives to Fiberglass Attic Insulation
My coworker has an older house here in San Diego that does not have ANY attic insulation. He'd like to get some put in, but does not want the conventional fiberglass rolls (too itchy) NOR the blown-in cellulose (too messy). I know that for most readers, probably the initial instinct is to argue his reasons for not liking fiberglass or cellulose ... but if we can just overlook them ... Is there a reasonable alternative? Can you get rolls of cellulose? That would be non-itchy and non-messy....
jbk is offline   Reply With Quote
Old 10-07-2009, 02:38 PM   #2
Rewards Points: 582
You could have re-cycled newspaper
http://www.lowimpact.org/acatalog/wa...nsulation.html
or sheepswool
http://www.lowimpact.org/acatalog/th...nsulation.html
BTW my travel agent told me that it never gets too hot or cold in San Diego.
stuart45 is offline   Reply With Quote
Old 10-08-2009, 11:26 AM   #3
Rewards Points: 1,910
You can get encapsulated fiberglass that is wrapped to reduce itching.
Another option is spray foam (usually pretty expensive).
If he doesn't need much R value in San Diego he could cut foam boards to fit between the joists and spray foam them in. Or he could place the full 4x8 foam sheets on top of the joists (cutting around obstacles) and tape the seams.
But fiberglass or cellulose is a lot easier.
Old 10-08-2009, 02:52 PM   #4
long island, NY
recycled bluejeans! I think you can get it in rolls from either lowes or homer..... $$$, but it's a DIY, and it doesn't have any formaldehyde either....
diy'er on LI is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Where to go for the best price for fiberglass batting insulation? diy'er on LI Building & Construction 7 08-24-2009 04:01 PM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
