Alternatives To Azek? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2008, 05:00 PM   #1
CareBear
Alternatives to Azek?
I would like to use something like Azek for some new exterior trim. But the nearest Azek dealer is 60+ miles away. Funny, there seems to be a Home Depot across the street from every StarBucks around here. I'm wondering if there are any alternatives to Azek that might be easier to acquire.
CareBear is offline   Reply With Quote
Old 06-21-2008, 05:17 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Try contacting a local lumber yard. You can also look into these:
Koma: http://www.komatrimboards.com/index.htm
Kleer: http://www.kleerlumber.com/
- Build Well -
Old 06-23-2008, 08:34 PM   #3
remodeling pro
Azek and Kleer are at the top of the heap IMO. Stay away from the stuff you find at the big boxes. It has a cheap inner core, and the finish is very brittle and cracks easily. I have no experience with the Koma products referenced by Atlantic WB, but if he is confident enough to mention it, I think is is certainly worth a look; his posts are always knowledgable.
troubleseeker is offline   Reply With Quote
Old 06-23-2008, 08:35 PM   #4
yep...
- Build Well -
Old 07-30-2012, 01:31 PM   #5
VerandaHP??? versus Azek
I am replacing the fascia on my home. It is a 19' run. I can only find Azek in 18' lengths at my local lumberyard, and Home Depot only carries it in 8' lengths. Therefore, my choice is to buy 2 18 footers (very expensive and lots of waste), or buy 3 8 footers from Home Depot and have 2 joints (which I will glue). Looking further, I have found VerandaHP at Home Depot which is S4S with sealed edges, is less expensive than Azek, and comes in 12 foot lengths. Is there something wrong with VerandaHP? It is supposedly the same material as Azek, but better. Any advice???
JMattero is offline   Reply With Quote
Old 07-31-2012, 04:12 AM   #6
Maryland
Versatex would be another option.
Pittsville is offline   Reply With Quote
Tags
azek , home depot , pvc , trim
Alternatives to dry wall!? tscott General DIY Discussions 12 12-23-2010 10:27 AM
"Green" alternatives to floor refinishing Chel Flooring 2 05-24-2008 12:24 AM
Tar alternatives ? jwryan Building & Construction 4 02-05-2008 03:29 PM
rolled roofing alternatives? timtreva Roofing/Siding 1 09-13-2007 01:12 PM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
