Alternative To 'flex Wrap' For Flashing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2008, 09:44 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,032
Alternative to 'flex wrap' for flashing?
What alternatives do I have for flashing my door besides tyvek's flex wrap, which the local hardware store wants to charge 170 dollars for a 7" X 25' roll.
Obviously that is the easy route, but I can't find any products that are similar at all. Am I stuck with metal flashing? ; because i'm not sure I could do that.
Journeyman Plumber
Old 07-26-2008, 05:26 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Grace Ice and Water Shield. Other flexible membrane materials. The difference is that you have to cut, peel, and layer it wall properly. Not a big deal.
- Build Well -
Old 07-26-2008, 06:38 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
I would use both, The grace as Atlantic states And the metal drip cap.
Old 07-26-2008, 07:47 AM   #4
Registered User
Termite's Avatar
Either of those products will work just fine.
I will say that Tyvek's flex wrap is uber-expensive, but is a spectacular product. If you're wrapping the house in Tyvek, the wrap's adhesive chemically bonds to the house wrap for a watertight seal.
Old 07-26-2008, 11:10 AM   #5
Doing it myself
Alan's Avatar
I can't find any other products besides the tyvek flex wrap in this town.
Looks like i'm going to have to order online.
Have you ever seen/used tite seal ?
Journeyman Plumber
Old 07-26-2008, 12:15 PM   #6
747
registered
747's Avatar
Rewards Points: 528
grace vycor and call your local lumber yard and see what they have instead of tyvek.
747 is offline   Reply With Quote
Old 07-26-2008, 12:17 PM   #7
747
registered
747's Avatar
Rewards Points: 528
Oh when i had my house vinyl sided i went with green guard house wrap instead of tyvek.
Old 07-26-2008, 09:51 PM   #8
Doing it myself
Alan's Avatar
Thats the problem, the local yard doesn't have ANYTHING.
Went to the next town and 1 lumber yard had the tyvek flex wrap, which I absolutely am not paying that much for .
Guess an adhesive membrane IS the way to go, so i'll look around and see what I can order online.
Journeyman Plumber
Asbestos Duct Wrap jvc120er HVAC 16 02-19-2012 05:19 PM
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 06:07 AM
No House Wrap On New House JoeZ430 Building & Construction 34 11-29-2007 10:51 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 02:30 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
