Is All Purpose Drywall Compound Not Strong Enough? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-22-2008, 01:57 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Is all purpose drywall compound not strong enough?
Should I be using a mix of all purpose compound, and type "90" for my seams, instead of all purpose?
Will it be strong enough? Or will I have cracking?
Should I be switching and do a 50/50 mix?
yummy mummy is offline   Reply With Quote
Old 04-22-2008, 01:59 PM   #2
Registered User
Termite's Avatar
All purpose will work fine. Cracking results when you try to put too much mud on in one layer and the drying of the mud causes it to crack.
Use thin coats and you'll be fine with all purpose.
Old 04-23-2008, 01:04 PM   #3
Thanks for the response t.
I was told that all purpose does not have the strength in it, if there is going to be "movement" later on, and that it would crack.
Is that true.
I have only put on the tape so far with thinned down all purpose.
Old 04-23-2008, 01:35 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
YM, as stated, it's fine (100% all purpose compound), when used with paper tape.
It's what it is designed to be used for.
- Build Well -
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
