Aligning Walls To Ceiling Joists? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 03:11 PM   #1
Aligning walls to ceiling joists?
So i'm framing my walls in my basement, and I've noticed that my top plate is not aligned to my ceiling joists..my framing corners however are 90 degrees (triple checked), but I'm finding my concrete walls are not straight. Is that going to be a problem? It just looks off as i'm framing, i'm sure once the drywall is up I wont be able to tell much..
Should I be worried?
dstylez is offline   Reply With Quote
Old 03-12-2009, 03:27 PM   #2
Remodeling Contractor
Seems like you are doing the basement wrong anyway. The bottom stud must be pressure treated. The tops can be shimmed if needed to be tight to the ceiling joists. The exterior wall if this is a below grade basement should have 1" closed cell rigid insulation or spray insulation to act as a capillary break to stop water transfer from the soil outside as well as a warm surface on the concrete to prevent condensation on the concrete wall. A 1" space should be provided to allow air flow behind the wall to allow any eventual wet condition to dry.
Old 03-12-2009, 03:48 PM   #3
When did I say anything about the bottom stud? My bottom plate IS pressure treated. And my walls aren't up against the concrete walls.
Old 03-12-2009, 05:17 PM   #4
Registered User
Rewards Points: 5,236
Do you mean the walls are not parallel with the joists above? When checking 90* did you use multiples of 3-4=5 ? 12'-16'=20' or bigger if possible? Only be worried if you: use a paneled or gridded ceiling; floor tiles or different color carpet squares; anything with a pattern that would show walls out of whack. Sorry previous sentence doesn't apply. Worried about not following foundation walls- only at the exterior door or window jambs, maybe a five footer, you might discern a difference in depth. GBAR
Old 03-12-2009, 05:45 PM   #5
Yes that's what I meant.
And yes I used the 3-4-5 rule and everything adds up just right. My concern was the window area, but I don't think it'll be too much of an issue.
Problem is though, I am planning on putting a dropped ceiling, however most of the walls will have soffits to cover up the ducts, so I might be able to get away with that there and compensate in case the grids are off.
What first ?! Ceiling or Walls? Do I need to prime? yohan Painting 6 07-26-2008 11:35 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
hanging ceiling above the joists?.... mben Building & Construction 18 04-01-2008 05:47 PM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 05:26 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
