Alaskan Slab Footing Depth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2006, 08:15 PM   #1
Need Information about an Alaskan Slab and Footing Depths.
new builder is offline   Reply With Quote
Old 06-14-2006, 08:55 PM   #2
Floorwizard's Avatar
I am Alaskan, but I know nothing of it.
hope you get help on this
Floorwizard is offline   Reply With Quote
Old 06-15-2006, 06:48 AM   #3
General Contractor
joasis's Avatar
Well guys, you contact the state's building code inspectors or whatever they are there, and ask questions. They will probably give you the general info for the area.
joasis is offline   Reply With Quote
Old 06-15-2006, 11:12 AM   #4
Rewards Points: 150
Southeast? North slope? Continuous or discontinuous permafrost? Earthquake/landslide/avalanche zone? Depth to water table?
I recommend calling the local building inspector and checking the codes.
billinak is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
