Airblocks Underneath Knee Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 05:38 PM   #1
airblocks underneath knee walls
Hello. I have a cape style home with knee walls. I have heard that I should block the airflow in the joist cavity directly beneath the knee wall. If there is insulation batting there already, should I cut the batts, fit the block, then start the batts over again? It seems I should not just squish the batts to install this air block. And, is carefully cut and calked bead board good for this purpose? Thank you.
bob with 4 dormers is offline   Reply With Quote
Old 12-05-2008, 04:19 PM   #2
okay, so I had to google knee walls, my sister's house has them but wasn't sure, anyway, here is nice piece on it,, hope it helps you
http://www.hgtvpro.com/hpro/bp_frami...243849,00.html
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-05-2008, 04:42 PM   #3
dude thanks
Old 02-15-2009, 12:11 PM   #4
Answer to your question
Bob, did you ever get an answer to your question? The site that was mentioned was really good, but didn't address the question on how to block the floor cavity below the knee wall. I have the exact same question.
THanks
Vermont1 is offline   Reply With Quote
Old 02-15-2009, 04:21 PM   #5
Rewards Points: 5,336
THanks
You can use rigid foam insulation and cut it so it's tight to the joists. If it's too loose, spray in some foam insulation from the cans to seal the edges.
Ron
Old 02-15-2009, 04:31 PM   #6
My area behind the knee wall was actually insulated & rocked before the knee wall went up. Then the knee wall was also insulated w/R19
So equiv of R38 to R44 insulation. The knee wall area stays warmer, but that heat is kept away from the roofing
My knee wall area is also used for storage
Old 02-17-2009, 10:52 AM   #7
followup question
Ron
Ron, I have a subfloor layed behind my kneewall that has insullation running along the floor joists. Just want to make sure I understand what I need to do. I think what your saying is that I need rip up enough of the subfloor behind the knee wall to insert rigid foam insulation. That means I will have to also cut part of the already existing insullation that runs the length of the joists to put the rigid foam in.
Tags
air block , insultion , knee walls , pressure barrier
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Trusses, collar ties and knee walls Ricki Lee Building & Construction 1 03-20-2008 08:29 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 09:02 PM
