Air-sealing Attic At Masonry Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 02:07 PM   #1
Air-sealing attic at masonry walls
I have a 60 year old 2-story brick house with wooden gable ends in the attic in Eastern PA (Philly suburbs). The exterior walls are plaster skim on 3/4" cement lathe board attached to the exterior walls with 3/4" furring strips and no insulation.
This fall, I'm planning on blowing cellulose into the attic to bring it to R-38, and before I do that, I understand that I need to seal the air leaks to the attic.
On the gable ends of the house, the tops of the walls are simply open - the lathe board sticks a few inches up into the attic past the finish ceiling and I can look right down the wall cavity (such as it is) for the entire length of the house. Needless to say, those walls are COLD in the winter (so are the others, to be fair).
Should I seal the top of this with foam/backer rods, leave it open because this chimney effect is vital to moisture management, or attempt to get as much cellulose down the wall as I can from above?
If I shouldn't seal it, what's the best way to protect the opening when I blow in the insulation?
Additionally, I have a bathroom opened up on the ground floor that has one of these exterior walls. Does it make sense to put 3/4" insulation board (R 3-4.5) between the furring strips, or is it a waste of time and money?
jackbird is offline   Reply With Quote
Old 09-01-2010, 02:51 PM   #2
Registered User
Rewards Points: 5,466
Brick clad background: http://docs.google.com/viewer?a=v&q=...-JZGbYlWDHwkSQ
http://www.buildingscience.com/docum...gs?full_view=1
Cellulose dense packing: http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
You’ll like this one: http://www.wag-aic.org/1999/WAG_99_baker.pdf
The air leaks: http://www.rd.com/how-to-seal-attic-...icle18158.html
Balanced ventilation: http://www.airvent.com/homeowner/pro...it-specs.shtml
Are there any knee walls/attic upstairs?
Is there any sheathing on the outside studs to hold the insulation as you need the air space at brick/wall.
Gary
Old 09-26-2010, 10:38 PM   #3
Rewards Points: 956
this is going to be a pain in the butt!!!!!
federer is offline   Reply With Quote
sealing painted basement walls cmt9000 Remodeling 3 07-06-2010 11:26 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Planning stages of an attic remodel... input appreciated... enenen Remodeling 2 12-17-2008 01:34 PM
sealing a masonry hole for a wire mcvane Electrical 2 06-18-2008 09:18 PM
