Air Movement In Wall Cavity - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 12:54 PM   #1
Rewards Points: 79
Air Movement in Wall Cavity
The insulation and sheathing on this exterior bathroom wall shows signs of what look like air movement. The insulation was very dirty in area's as well as the sheathing. The sheathing doesn't seem wet and I'm not sure if the dark area's are signs of mold or just dirt from air moving past. There were small pieces of fiberglass insulation wedged in between the sheathing and the studs to fill in the gaps that are there.
The wall construction is aluminum siding, house wrap, sheathing, fiberglass batt, 2 mil poly and then drywall with tile. The house was built in 1980 in the pacific northwest region.
How can I prevent this from happening again and what should I do about the current condition of the sheathing? I will be using 6mil poly with cement board when it's time to redo.
RalphPeters is offline   Reply With Quote
Old 05-31-2010, 02:08 PM   #2
ccarlisle's Avatar
You have air movement through a discontinuous vapour barrier or you have a hole in it. 2 mil is pretty scrawny as a vb, so replace it with something like 6 mil and then tape the seams.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 05-31-2010, 03:51 PM   #3
Rewards Points: 79
Thanks, so should I use caulk between the sheathing and the stud where the air is passing through as well? If the air is passing from the cavity shown to the one next to it (which would be in the next room) how far should I go to try to eliminate this movement.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
