Air-gap Between Rigid Floor Insulation & Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 11:37 AM   #1
Air-gap Between rigid floor insulation & subfloor over concrete
I am building an addition in what used to be the ground level attached garage.
I've researched all about proper insulation and vapor barriers for the concrete floor. I know all about the products that are available. I was actually going to install myself, but ran out of time and had to hire someone to do it.
My problem is trying to get my contractor to deviate from his way, his "old school" way. The concrete floor has a slope in it, so he is building a leveled platform subfloor over it. He was just going to use plastic sheet for barrier, and no insulation. I insisted on at least putting rigid insulation over that, so he's going to drop in a layer of it in.
My question is, since there is a slope, this will create an air gap at the lower end of the slope between the subfloor and insulation. Will this air gap negate the effects of insulation?
Also, there is a floor drain in the concrete for the garage that is being covered. Is it necessary to seal that up?
acerunner is offline   Reply With Quote
Old 02-21-2011, 07:05 PM   #2
Registered User
Rewards Points: 526
"My question is, since there is a slope, this will create an air gap at the lower end of the slope between the subfloor and insulation. Will this air gap negate the effects of insulation?" ----- yep; The "biggest loser" in fiberglass insulation....
Gary
Old 02-22-2011, 03:03 AM   #3
d it. that's what i figured.
any suggestions on a remedy for this situation?
Old 02-22-2011, 08:41 AM   #4
glue to the underside of the joists and prop it up as you go. Fill between joists with fiberglass
mrgins is offline   Reply With Quote
Old 02-22-2011, 12:36 PM   #5
K thanks. The plastics sheets need to be taped our glued together also right? I'm pretty certain im right bout that. Contractor insist simply overlapping the sheets is enough.
Old 02-23-2011, 03:33 PM   #6
Registered User
Rewards Points: 526
I would not use plastic (impermeable) sheeting. Either equalize the vapor pressure using FL or Fig.#3; http://www.buildingscience.com/docum...ms?full_view=1
OR coat with a product as in fig.#2 letting it dry to the inside room above.Summer time problems.
Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
