Old 03-03-2013, 02:35 PM   #1
Exclamation
Air compressor with Nail gun
My cousin already has a 4 gallon air compressor that runs 2.8 SCFM at 90 psi.
http://www.homedepot.com/webapp/wcs/...a#.UTOTRBy1k60
Will that be ok to use with;
http://www.harborfreight.com/air-too...html?hftref=cj
Mijotter is offline   Reply With Quote
Old 03-03-2013, 03:17 PM   #2
You posted two bad links.
If your talking about a framing gun, it needs more then 90 PSI to work right and I belive most call for about 3.5 CFM.
To small a compressor and you can look foward to having to hand set the nails and wait for it to catch up.
Old 03-03-2013, 03:30 PM   #3
ugh, sorry for the bad links.
Air compressor:
http://www.homedepot.com/Tools-Hardw...1#.UTOyEVewT_k
Nail Gun:
I don't know if it matters but i won't be using this gun and compressor for nailing to concrete, just 2x3's.
Old 03-03-2013, 03:38 PM   #4
It should work for what little you need it for.
I sure would not go out and buy one.
Old 03-03-2013, 04:01 PM   #5
Thanks Here's hoping...
Old 03-04-2013, 07:18 PM   #6
Exclamation
Ok yeah you were right. That tank will not work. I was looking at Home Depot and found this compressor. Seems it will handle the job. 4 CFM at 90psi and 5CFM at 40psi.
http://www.homedepot.com/h_d1/N-5yc1...1#.UTUzy1ewT_k
What do you think?
Old 03-04-2013, 08:48 PM   #7
if it is a small job there is nothing wrong with hand nailing. its cheaper and you get more excercise.
Old 03-05-2013, 12:12 AM   #8
Yeah if it gets too much more expensive I'm hand nailing even though I've never framed that way before. Should that 8 gallon be good? I read it's continuous pressure for framing.
Old 03-05-2013, 07:42 AM   #9
I agree. And even large jobs aren't that difficult. My wife and I built our log home ourselves, and hand nailed all the interior framing. I do have a couple of smaller pneumatic nailers, but the framers scare the heck out of me. We've worked several builds with Habitat for Humanity, and volunteers aren't allowed to touch them.
Old 03-05-2013, 08:07 AM   #10
AHH, SPANS!!!
guys with their finger always on the trigger are what scares me with nail guns, I've been shot by someone doing just that and it is the first rule you learn when using a nail gun- do not keep the finger on the trigger unless you are 1 second away from shooting into wood. don't hold your finger close to where you are shooting also because nails will curl and stick back out of the wood in weird ways sticking you if your hand is there.
hand drive is offline   Reply With Quote
Tags
air compressor, framing, nail, nail gun, wall
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Nail in Top Plate Basement buildit45 Building & Construction 5 04-10-2012 03:56 PM
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 06:31 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 01:21 PM
Nail Gun Plastic Nail Casing frustrations smark General Discussion 6 07-07-2008 09:10 PM
