Air Compressor Breather Oil Discharge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 09:54 AM   #1
Air compressor breather oil discharge
I have a 20 yr old Campbell Hausfeld cast iron 20gal/4hp compressor that is bubbling oil out the crankcase breather. The oil level is correct. This unit has not been used for several years because of a bad tank, but has been run a couple of times. The problem occurred with the installation of a new tank. Tank pressure is 100 PSI which is the second problem as it should max at 120 PSI.
Thanks for your help.
Oliversuper55 is offline   Reply With Quote
Old 07-23-2012, 11:57 AM   #2
AGWhitehouse's Avatar
Maybe that old motor is showing it's age. My have piston bypass which is pressurizing the crankcase, hence the blow out at the breather.
Does it happen even when the tank is at 0 psi and just beginning to fill? If not, does the oil seepage increase proportional to the tank pressure? If so, then it's likely piston ring bypass.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-23-2012, 12:07 PM   #3
Rewards Points: 106
Could also be condensation in the oil; when was the last time that you changed it?
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Sump pump discharge set-up moneymgmt Plumbing 23 02-25-2012 11:46 PM
Configuration of 2 ball valves on Sump Discharge Line chsitko Plumbing 3 11-25-2010 09:13 AM
Aprilaire 350 duct size and discharge StahlMaster HVAC 7 03-23-2010 08:17 PM
two discharge lines on compressor? cmac HVAC 2 05-31-2008 09:16 PM
