Some time in the fall, I want to convert our attic into a usable space. Since this will become a conditioned space, the insulation plane will need to move from the 2nd story ceiling to the roof line. I had already had some exterior walls insulated with Icynene (none of the walls in my 100 year old house are insulated) as I was remodelling those rooms and I am very happy with the performance of that product, esp. in terms of its effectiveness as an air barrier.
I have done some research and it appears that for cathedral ceilings, the typical insulation details include an air space between the roof sheathing and the ceiling insulation.
1. Will I need to install baffles (or build something similar) on the underside of the roof sheathing before having the Icynene sprayed in?
2. Assuming that I do, it would stand to reason that I would still need soffit and ridge venting?
3. Finally, when this type of conversion is done, is it customary to remove the existing ceiling insulation? I know that I'll need to remove some (it is blown in at a depth of about 3 ft.) in order to deck over the joists but I wanted to know if all the insulation needs to be abated?
My house is located in Illinois, just outside of Chicago.
There are rafter vents that can be stapled to the underside of the roof underlayment which will hold a 1" or 2" (can't remember) void to transfer air from the soffit to a ridge vent or void at the peak. I googled this as an example:
I've seen these at Lowe's and Home Depot. They come in a rigid foam as well as plastic. If it were me, I'd go with plastic since the foam kinda seems like it could be crushed or pierced easily.
Yeah, I know what they are and I've seen them at the big boxes. The question was more of whether I need to use them with spray in foam insulation, s'all!
The attic gets so hot, and now the attic will be a living space. Is there information on how this spray foam reacts under high temperature and whether it offgasses?
The product that I've used is called Icynene and as far as I know from talking to the company, there is no restriction to its use for this particular application. That being said, I doubt that it off-gasses but I can check the website where they have all of the technical information.
Here's my real concern. In the winter months (this is northern Illinois), if warm air from the conditioned space leaks into the attic (currently not conditioned), it can condense and cause problems such as mold and possibly rot. When you insulate the inside of the roof, I'm thinking that the air space that you'd create would be to keep both sides of the roof at the same temperature.
Now, for this application, I'm thinking that a vapor barrier would be appropriate which would stop the movement of moist air toward the cold roof. So, basically in this instance, I'm thinking that the baffles/air space would be necessary to deal with any moist air that does leak by. But, in the case of a spray-on foam insulation, one of its benefits is that is completely seals the void and because it is not air permeable, it acts as a complete air-barrier. So, the chances for moist air to actually reach the cold roof sheathing should be pretty much zero. This is why I question that the baffles are needed for this type of insulation material.
The more I research this, I'm finding a lot of differing opinions in the "sealed attic" concept. And yes, I can simply ask the installer for their recommendation or simply go ahead and install the baffles but I want to go into this educated.
Again, I'm not an expert here, just thinking things out. Feel free to chime in!
the air space would allow the typical cooling of the roof surface that is designed to prevent ice dams. IF the insulation 100% prevents this, it would be a non-issue.
I also believe it is neccessary due to the fact that even if you prevent all moisture from below, you still have the possibility (actually probability) of leaking from above. Shingles do wear out and there will eventually be leaking. I believe the air space would allow any moisture that does pass through the roof to evaporate out and prevent the wood from being damaged.
This would be similar to the EIFS system problems that happened with sidewalls. EIFS is where they place foam board on the wall and the overcoat with synthetic stucco. Originally, no drains were provided for entrapped moisture and it caused a huge problem with rot in the walls. Eventually, drain systems were employed to prevent this. I would think the roof situation would act in a very similar manner.
Nap, my electrical pal. Nice to hear your input in a non-electrical forum.
Yes, I totally agree that in a vented attic, the soffit vents allow the cold outside air to cool the inside surface of the roof to keep warm air from melting snow only to have it form as ice when it hits the overhang. But, let's say that you now effectively create a 10" thermal, air-tight barrier between the warm inside space and the freezing outer roof temp. If we can prevent inside thermal energy from melting the snow, we've overcome this issue. I must admit though, it seems strange not to have the air space.
I absolutely agree with you point BUT continue reading my post and you will see that I also am concerned about water infiltration from the outside due to roof damage or shingles wearing out. I would think that water/moisture would need the air space so it can be evaporated out of the wood of the roof. If not, it would simply rot the wood as it would have no place to escape to and no method for drying the wood.
Like I said, this is a totally untrained view but it seems logical to me.
After some additional research, it seams icynene is an "open cell" foam and as such, will permit water vapor through so it would seem the foam against the wood my not make any difference. Personallly, I still believe I would consider that air space. Take note of the concern for shingle damage and warranty loss in the ask the builder link.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
