Affixing PT 2x4 Sole Plates To Concrete Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 03:12 PM   #1
Rewards Points: 1,062
Question
affixing PT 2x4 sole plates to concrete foundation
hi, i have an 11x9 concrete slab that i am getting ready to build a shed upon. the foundation footer is 2 ft deep and 10" thick, the slab inside is about 3-4" thick.
i am wondering whether i should use power-actuated 3 in nails to affix the 2x4 sole plates, which would be the easiest, or drill holes in concrete and fasten them with bolts and anchoring epoxy. one problem i've had in the past with nailing wood to concrete near an edge (which would also be the case here) is that it can chip the side of concrete if too close, within an inch or so. holes/bolts require more calibration and is more intensive to do but the side of concrete would be safe.
thanks
Old 12-21-2010, 03:23 PM   #2
Not sure of all the variables here but I would go for a 1/2" diameter bolt or rod epoxied into the concrete. Just be sure you clean out the drilled hole before you start placing the epoxy.
Nucon is offline   Reply With Quote
The Following User Says Thank You to Nucon For This Useful Post:
amakarevic (12-21-2010)
Old 12-21-2010, 03:49 PM   #3
Rewards Points: 5,336
You can also use bolts that are friction fit in the hole.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 12-21-2010, 04:06 PM   #4
Civil Engineer
Rewards Points: 4,856
You did not indicate where you are located. If in a cold environment, the epoxy is not going to work until Spring. I like the 38 Ramset tools (I assume you meant powder actuated, not power actuated, which is a different beast entirely), however as you indicated you are likely to crack the concrete if you are not at least two, better yet 3 inches in from the edge.
If closer to the edge, you can certainly use expansion anchors like a Phillips Redhead, just takes a little longer than a powder actuated pin. Some people here like Tapcons, I don't particularly like them for heavy duty fastening. The old fashioned option is drill and use lead shields, they work OK also.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 12-21-2010, 04:09 PM   #5
Question
yes, POWDER-actuated, sorry. they have fast-set anchoring epoxy too, will that work better in cold weather ?
Old 12-21-2010, 07:10 PM   #6
Hi
Your second option is best - resin anchors, as they put no tensile load on the concrete.
As for weather conditions you will need to check the spec on the product and find one that is suitable or put the job off to a warmer time of year.
Regards
GJ
hereslookingatU is offline   Reply With Quote
The Following User Says Thank You to hereslookingatU For This Useful Post:
Old 12-21-2010, 08:28 PM   #7
Frame the walls, tip them up, pin with ramset, then drill 4' oc for wedge anchors
HarknessConst is offline   Reply With Quote
The Following User Says Thank You to HarknessConst For This Useful Post:
concrete over cinder blocks for foundation?? Birdman79 Building & Construction 10 11-24-2010 01:32 AM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 03:57 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 01:01 PM
Garage - Rotten Sole Plates disinmtl Carpentry 2 08-07-2009 08:55 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
