Old 01-18-2011, 09:18 PM   #1
Advice: Shed Plans/Insulation Question
I am planning a shed for this summer. I want to finish it off inside and use it as an office. I was going to use these plans.
http://www.mybackyardplans.com/gablestorageshed.php
I want to insulate it, drywall it, and put a small wood stove in it. I'm going to mostly follow the plans but want to put in a single door with a small window on each side of it. I live in Northern Pennsylvania so the winters can get a bit chilly. I was going to use fiberglass batts and drywall for the walls but wasn't sure about moisture. I don't have experience with this. For the floor I thought I would put down a vapor barrier and a hardwood floor. I think I need to use thicker plywood (at least 3/4) than the plans call for. A wood stove in this small space will really heat it up so I'm not worried about going nuts with the insulation but do want to keep the critters out. It's going to be built on skids just like the plans. I'm unsure about insulating the roof or ventilating. How I finish off the ceiling will depend on what I need to do for insulation/ventilation. Thanks for any help!
lukabrazi is offline   Reply With Quote
Old 01-18-2011, 09:52 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Keep in mind, that if you finish the space, the local county taxing authority can consider it a taxable structure. Check with your city hall regarding how far you can go before they decide it is taxable.
gregzoll is online now   Reply With Quote
Old 01-18-2011, 10:08 PM   #3
Trailer Park Boy
shanekw1's Avatar
A shed is kind of an odd place for an office?
Just sayin'
And I'm pretty sure an 8'x8' shed would get ridiculously hot with more than a soup can wood stove in it.
What are you planning to do in this 'office'?
shanekw1 is offline   Reply With Quote
Old 01-18-2011, 10:11 PM   #4
I will definitely look into this before I start. I am assuming 8x8 on skids won't even need a permit where I live. After I know what the rules are for permits/taxes I will really be able to determine what size this is going to be.
Old 01-18-2011, 11:05 PM   #5
Here in my township, we only need a permit for a shed if it has a cement foundation.
Our 12' x 20' (?) shed is built on a wood frame with a plywood floor. Gophers, squirrels, etc. have tunneled underneath it and have chewed their way in. It's only used for tools, bikes, etc.
A cement foundation sounds better if you're going to have anything important in there.
Are you going to have electricity in your shed?
For insulation, I would use Roxul. Sprayed on foam might be even better if you don't want any drafts.
gma2rjc is online now   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
lukabrazi (01-18-2011)
Old 01-19-2011, 12:09 AM   #6
There won't be electric running to the shed. It is too far from the house. It's going to be out on a connecting parcel that I own. Sticking this on the roof. I don't need a lot of electricity (light, laptop, printer).
http://www.amazon.com/Sunforce-50044...=pd_sim_auto_4
I really like the looks of Roxul. I will have to see where this is available locally. If I insulate the walls and ceiling with Roxul and cover it with a vapor barrier can I just dry wall it in or do I need some sort of ventilation?
Old 01-19-2011, 12:42 AM   #7
I've never built a house or shed, so hopefully someone more knowledgeable will answer that. But I'm pretty sure you will need some kind of ventilation.
Old 01-19-2011, 07:35 AM   #8
Do I need a ridge vent and soffit or if I can just stick a couple of wall vents in opposing sides of the peak?
Old 01-19-2011, 04:57 PM   #9
Checked with the township. As long as the construction cost less than $1,000 and it is under 750 sq feet no permits needed. I questioned the 750 sq feet because that seems like a lot but he said it was accurate. Either way I won't be anywhere close to that. I will probably shoot for 10' x 12'.
Old 01-19-2011, 08:08 PM   #10
Moderator
Ridge and soffit if insulating the ceiling flat plane or go with non-vented insulated sloped ceiling; http://www.buildingscience.com/docum...r-all-climates
Otherwise a high and low vent on opposite ends or sides. Not per directions; run plywood perpendicular to joists, tar paper walls if insulating, use a ground cover plastic under all framing, waterproof treat the p.t. wood underneath, run T1-11 down past floor deck 1" for drip edge, add trim board to walls then run rafters for sheathing to lap past 1" for drip edge, add metal drip at roof bottom, add metal drip flash above window and door. http://www.buildingscience.com/docum...r-all-climates
http://www.buildingscience.com/docum...ecommendations
http://www.buildingscience.com/docum...vapor-barriers
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 01-19-2011, 08:18 PM   #11
gregzoll's Avatar
750 sq ft is a little under what my house is (about 100 sq ft). So, basically you could build a 1 bed/1 bath house, and your township does not care.
Old 01-19-2011, 08:50 PM   #12
DIY Hack
Mr Chips's Avatar
I think you are forgetting the "cost under $1,000" part of the requirement
OP, I have that same Sunforce deal that I bought for my shed. I only ended up using two of the panels, since I only run some LED lighting. Does a great job keeping my deep cycle battery charged
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-19-2011, 09:01 PM   #13
gregzoll's Avatar
That would fit in with how some of the houses/shacks that are built out in the country in this county. Makes you wonder what some people are thinking. Then again, there are garages in this town that should be condemned in my town.
Old 01-20-2011, 04:30 PM   #14
I wonder how they prove the cost under $1,000.
GBR thanks for the good info. The ceiling won't be flat plane so a non-vented ceiling sounds the easiest. By high and low vent do you mean a wall vent?
Old 01-20-2011, 07:45 PM   #15
Moderator
You just want air changes, depends on how warm the equipment gets. One low (with an outside cage for critters), and one in roof or high wall, opposite end/side. The box stores sell them for outside make-up air to bedrooms with a gas furnace, 6" round, adjustable, closing, etc. white plastic to fit 2x4/2x6 walls.
Glad we could help.
Gary
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 11:31 AM
Shed Roof Truss Question Gravel7 Carpentry 1 10-08-2009 07:13 AM
Question: Altering One Side of a Gable Roof to a Shed Roof willcmjr Roofing 11 09-17-2009 05:32 PM
wiring electrical in a shed patrick29 Electrical 11 08-22-2009 04:46 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
